What kinda Sparkplugs should i use if im N/A??
Old Jan 7, 2006 | 02:07 AM
GAaaAR's Avatar
GAaaAR
Default What kinda Sparkplugs should i use if im N/A??
The title says it all. So what do you guys think? Would it make a noticeable difference at all? I figured it so cheap so why not.
Old Jan 7, 2006 | 03:06 AM
Fairlady_z33's Avatar
Fairlady_z33
t think it will really make a difference but hey go for it.
Old Jan 7, 2006 | 03:34 AM
SpeedRcr's Avatar
SpeedRcr
i changed mine out at 35k miles to denso iridiums...my mpg went up which is always a plus...
Old Jan 7, 2006 | 08:12 PM
How many miles do you have on the car?
Old Jan 8, 2006 | 12:21 AM
Dubai's Avatar
Dubai
I went with ZEX 2 step colder, I also have NOS thats why I upgraded the plugs. but to be honest I dont use the NOS often and the plugs have been on the car for 7k miles and running strong so far.
There is no noticeable difference when you change the plugs
Old Jan 8, 2006 | 04:24 AM
GAaaAR's Avatar
GAaaAR
I've got about 25K miles on my car so far. So are plugs a waste of money if my car is NA? or would it still help? I dont plan on going F/I or Nos.
Old Jan 8, 2006 | 06:28 AM
SpeedRcr's Avatar
SpeedRcr
plugs will help...
Old Jan 8, 2006 | 06:54 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
at 25K I'd save your money
Old Jan 8, 2006 | 10:27 AM
If the car has 25,000 miles and runs well, leave the sparkplugs alone.
Old Jan 8, 2006 | 10:34 AM
Vamos_Rafael's Avatar
Vamos_Rafael
get good performance plugs, every little helps...
and of course get grounding wires too
Old Jan 8, 2006 | 11:13 AM
davidf's Avatar
davidf
BTW who sells Dinso Iridiums.
Old Jan 8, 2006 | 12:12 PM
bleunetizen's Avatar
bleunetizen
i got ngk iridium 5s... should have gone for 6s.
Old Jan 8, 2006 | 05:29 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
what the different between 5s and 6s?
Old Jan 8, 2006 | 06:08 PM
bleunetizen
stock cars got 5's. The number indicates the heat range. Higher the number, colder the engine runs.
Old Jan 8, 2006 | 06:09 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
oh, so the 6s also called "cold plug" or 1 step colder something ???
Old Jan 8, 2006 | 06:21 PM
Z1 Performance
Former Sponsor
Denso Iridium: http://www.z1auto.com/prodmore.asp?m...ine&prodid=494
Unless you have SUPER high compression or SUPER high boost, stick to stock heat range
Old Jan 8, 2006 | 06:32 PM
bleunetizen
if you push your car hard, 6's might be better than 5's..
as long as they do not miss fire, colder plugs should be better for ur engine as well..
The main reason why i regret getting iridium 5's is because my platinum was in good condition, and i knew they were in good condition before buying the iridiums. I got 5's and regapped it to 1.1mm. Since its getting hot here, 6's couldve been a better choice. Even service manual recommends 6's for hard driven cars.. so yeah
Old Jan 8, 2006 | 06:43 PM
Z1 Performance
Former Sponsor
you've got to explain this one to me......
Old Jan 8, 2006 | 08:50 PM
islandsnow's Avatar
islandsnow
i have the ngk lfr5aix-11 iridium ix plugs, the car runs a lot smoother with em. you can find them cheap on e-bay.
Old Jan 8, 2006 | 10:19 PM
bleunetizen
it will simply cool the cylinder temperature and plug temperature down. If the temperature goes up or down too much out of the optimum heat range you risk miss-firing the fuel mixture. This depends on motors but 5 is a HOT type. 90% of turbo or high compression cars from japan use heat range of 6 stock standard, and many NA cars with high compression (s2k, prelude types, etc) or high boost above 1bar run 7 even 8 in some cases.
What I found is that my stock platinum plugs were overheating at times, i could tell by reading the colour of the tip after i pulled it.
