Who said it can't be done?
Old Jan 19, 2006 | 11:46 AM
  #221
Julian@MRC's Avatar
Julian@MRC
Originally Posted by Javi
My brother has "only" 460+whp on his '03 350 (webcarconnection) not 600+whp like Sharif, and every time we go to the Dynojet, we have to open the trunk of the car and I have to sit in the back (not very comfortable I might add, even less when you are 6'4" and 300lbs like me...) because of traction problems.
Then eithier your using Rollerskate wheels or their not strapping down the car properly..I have seen 800-1300hp mustangs at the shop we use, not loose traction.
Old Jan 19, 2006 | 11:48 AM
  #222
Quamen's Avatar
Quamen
It prolly depends on the dyno also. How much the roller has been used and what not. I have seen some really high HP cars not lose traction, but I have also seen some lower HP cars lose traction on the dyno.
Old Jan 19, 2006 | 11:50 AM
  #223
phunk's Avatar
phunk
CJ Motorsports
yea there is no reason the car shouldnt be able to hook up if it has remotely OK tires on it. Either their rollers are old and worn of their knurling, or not clean, or the car is not strapped right.
Out of the hundreds of cars that I dyno'd, I never had problems with tires spinning... imports to muscle cars, turbos to supercharged vipers making well over 600ftlbs before 3000rpm... never had problems with spin.
Old Jan 19, 2006 | 11:52 AM
  #224
Julian@MRC's Avatar
Julian@MRC
I guess the laws of physics do not apply in NC... Seriosly I dynod my car with slicks on it and had a little bit of tire spin, but we simply ratched down the straps a bit more and no problem..I guess Shariff's car needs some new tires..
Old Jan 19, 2006 | 11:59 AM
  #225
phunk's Avatar
phunk
CJ Motorsports
dynoing on slicks can be hard because they collect a lot of dust and also need to be warm to get the extra grip... and its not always the best idea to strap down super super tight on slicks as your putting a lot of pressure and drag on them.
If having traction problems on the dyno, i might suggest setting the cruise control and letting the car run at 60mph for 5 minutes... let the tires get nice and warm and the knurling will clean them off.
Old Jan 19, 2006 | 12:10 PM
  #226
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Originally Posted by raptorbh12
honestly, were your tires wet? I dont see how they could break loose if done correctly on a dynojet. Maybe they forgot to unlock the rollers.
The dynojet rollers were completely smooth and shiny. The knurling was 95% worn out. Believe me we tried everything, and the tires would not stick.
Just removed my broken axles, and the shaft snapped inside the inner CV. It was a clean stress fracture...that eventually worked it's way through 1 inch of solid steel. These axles are rated at 500whp, so it doesnt really suprise me, that they eventually snapped.
Old Jan 19, 2006 | 12:28 PM
  #227
ZON's Avatar
ZON
Whatever. When's the N/A car going back on???
Old Jan 19, 2006 | 12:30 PM
  #228
phunk's Avatar
phunk
CJ Motorsports
I have a solution here to find out what is really going on.
I just got off the phone with Kevin @ UnderGround Racing, he said that he would like the owner of this Z to call him back, and he will dyno this car for FREE tommarow (Friday).
So thats right, the owner of UnderGround is offering to dyno this car for free and the owner can just come in on Friday with a video camera and video the entire thing, and he will dyno the car with SAE correction.
Cant turn that down?
Old Jan 19, 2006 | 01:14 PM
  #229
Z350Lover's Avatar
Z350Lover
or can someone lend him a wheel/tyre setup to run on the dyno tomorrow... just don't know what his wheels are though.. that will be tough, if they are standard ones, that will be ezy!
Cannot wait to see the number and I am sure this number will be more accurate @ UnderGround Racing... sounds like the owner is willing to set this right for everyone here... good on him!
cheers,
richie
Old Jan 19, 2006 | 01:15 PM
  #230
G I Love My Car's Avatar
G I Love My Car
Phunk for one thing, I have a job which I took a day off to do this so I dont have all the time in the world to please u and another why should I. We had some unfortunate things happen today so we are going to try again. Second, if u read the post u would know that I need a new tire. So since u have all the time in the world to make my scheudule please find me a 275-40-18 Mich PS2 and then I can redyno. Third if there is bad blodd between underground and CP why in the hell would i take my car there, if u have think the numbers are fudge to make someone look good, dont u think that the numbers could be fudged to make someone look bad. So I think u need to ease of a little and things will happen. So call undergroud I undo the appt. u made for me. I will let u know when my sche. is free
Old Jan 19, 2006 | 01:20 PM
  #231
phunk's Avatar
phunk
CJ Motorsports
your taking this all the wrong way my friend.
just call underground and set it up when your available. kevin didnt say he would only do it Friday, he just said to tell ya to come in tommarow. no one is accusing you of not having a job or having too much free time.
and no, underground cannot fudge your numbers to make them look bad, cause on a dynojet 248c there is no where to fudge the numbers. that is why people trust it. regardless of CP and UGs relationship.. what do you care, just hop on the dyno and see what it does. What is the problem between CP and UG have to do with your dyno numbers?
If you dont wanna dyno at UG then fine... I suppose you can take it back to the shop that cant even get Sharif's car to hook up.
I am not forcing you into anything... all I did was get you a free place to dyno.
Do as you wish, I already feel I know the truth... so honestly I dont care much if you go thru with it or not.
Old Jan 19, 2006 | 01:29 PM
  #232
G I Love My Car
Well then please phunk enlighten me to what the truth is because I quess I dont know
Old Jan 19, 2006 | 01:31 PM
  #233
phunk's Avatar
phunk
CJ Motorsports
The truth is awaiting you at UnderGround Racing as soon as your available!
Please do not take so much offense to all this... you already said you knew the critics would come! Please understand mine and everyone else's position on this.
Old Jan 19, 2006 | 01:38 PM
  #234
Acree's Avatar
Acree
It sounds like you have a free dyno my friend. Call the company and set an appointment. Simple as Easy Bake Oven Cleaner!
PS. In all fairness, I REALLY do hope that you dyno 300hp or more. It would give all these nay sayers something to talk about.
Old Jan 19, 2006 | 01:39 PM
  #235
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
this thread, like so many others, is now a waste of time...it's like a freaking soap opera, combined with hints of Club Si
Mod's can we close this? When the owner of the has a Dynojet chart to show, I am sure he will start another thread
Also, tire rack has the tires on sale for $277 a piece if you still need one
http://www.tirerack.com/tires/Compar...rk=1&x=10&y=14
Old Jan 19, 2006 | 01:43 PM
  #236
002-M-P's Avatar
002-M-P
CPR and UGR are basically direct competition in Charlotte, NC. I have been to both before (dyno'd my rx7 at UG twice and my Z once), and had the Z tuned a few months ago by Sharif and Eric at CP. From what I have experienced they are both extremely nice and good to deal with, so I personally have no problem with either.
And just for another point. I dyno'd 345rwhp at UG when i first installed my TT kit. Then later on when at CP getting my tune, my baseline before upping the boost from "stock" was 355 rwhp (and this was with many more intake/exhaust mods than my 345 run). So, at the time of my dyno I was completely confident with CPR's dyno-scaling.
Old Jan 19, 2006 | 02:28 PM
  #237
eat rice z33's Avatar
eat rice z33
sounds like someone is getting defensive? whats up with puttin 314 whp in your sig? dyno on a dyno jet already, you got a free appointment, you got this whole thread anteed up for this day! DO IT DO IT NOW!!
Old Jan 19, 2006 | 03:10 PM
  #238
Alberto's Avatar
Alberto
Cranky FI Owner
Exclamation
Originally Posted by Fukatypr
I did find any.....
I'm calling BS on the fact that Alberto got 6mph from 20whp in a 3000lbs car. That just does happen.
I want to SEE timeslips!
Why doenst it happen, cuz you havent done it? Everybody knows me, Im no bull$hitter, I havent posted the actual scanned timeslips but I have posted the video and the breakdown of the slip. On the day I ran 13.13 and backed it with a 13.16 there were 2 other Z owners there, they both know me, and my car they can vouch for me. Car dyno'd 239whp stock, 262 with mods, on a dynojet SAE corrected. If you dont believe it, Im not losing sleep over it.
BTW here is the video of the runs below, I know you'll just say "I dont know what you have in there" If you want to discuss this further PM me, I wont hi-jack this thread anymore.
http://videos.streetfire.net/Player....rm=Alberto&p=0
Now back to the topic!!!
I havent been on here all day I was soooo looking forward to seeing this but no dice. Im glad my beanbag is still intact, but Im sorry to hear you have a nail in your tire, that sucks. Have any idea when you will have a replacement on or an eta on a new dyno day? Good luck to you, I hope you prove many of us wrong, it would be a HUGE step for NA Z's....
Old Jan 19, 2006 | 03:25 PM
  #239
phunk's Avatar
phunk
CJ Motorsports
Originally Posted by Z1 Performance
see what I mean...mods please....this is now useless
Close it??? I think we should sticky it!!! Hell, this thread has more useful info then other dyno related stickies I have read.
We are at almost 6000 views and 250 posts in a matter of a few days! We are catching up to the largest threads on this forum that have been around for months.
1 vote for sticky!
PS. is there a way to see how many people have subscribed to this thread?
Old Jan 19, 2006 | 03:39 PM
  #240
Rickdogg's Avatar
Rickdogg
Out of hiatus
All of that reading for no results
