Koyo Radiator porblems?
BTW, this procedure works on almost every car on the road. What you're doing is making the radiator cap the highest point in the cooling system. Air bubbles will always seek the highest point possible.
Originally Posted by jmckuhen
Just got back from the shop and the problem is fixed....i hope. Heat works now and the temp gauge is steady. They called nissan to find out how to get the air out of the system and it goes a little something like this......
Lift front end of car (very important)
remove radiator cap (make sure car is cool or you get spewage)
start car
run at 1500rpm for 10-15 mins with full heat blowing
replace radiator cap
lower vehicle
your done!
I believe this is exactally how he explained it to me. He also said that nissan did not have a special tool to do this, they just follow the procedure above.
Thanks,
Vince
start car
lower vehicle
your done!
Thanks,
Vince
