Dyno pre and post Utec
Old Jan 27, 2006 | 07:30 AM
raptorbh12's Avatar
raptorbh12
Default Dyno pre and post Utec
Im getting my car pre-dynoed today at extreme motorsports in odenton and then monday i am getting Utec installed and i will re-dyno my car after it has been tuned early next week.
My modifications so far are as follows: Helix test pipes, AAM plenum spacer, JWT pop charger, clutch, flywheel, pressure plate, AAM y-pipe, AAM reflash with retarded timing, UR crank pulley.
My guesstimate of pre Utec hp is 260 whereas i dynoed 257 minus the crank pulley and with advanced timing. any guestimates on pre and post hp?
Old Jan 27, 2006 | 08:33 AM
DomZ's Avatar
DomZ
I call 265 before, 285 after....I think your A/F may be all screwed up from all the breathing mods which only leaves more potential for gains from UTEC......
Good luck man!
Edit: I just read you have an AAM flash, I scale back my post gain to 275... you already have some tuning there.
Old Jan 27, 2006 | 10:03 AM
steela2110's Avatar
steela2110
I am with this dude! Post results!
Good luck man!
Old Jan 27, 2006 | 10:04 AM
RNL323's Avatar
RNL323
Mod My Ride
I'd go with 275 tops with your set up. If you had exhaust I'd say 280's....
Old Jan 27, 2006 | 11:43 AM
raptorbh12's Avatar
raptorbh12
i made 244 hp and 232 ft/lbs.... well looks like retarding timing gave me 13 less hp... lets hope a Utec can salvage these numbers
edit: ok theres gotta be something wrong with my car then, no way im making 13 less hp after adding an UR crank pulley and retarding the timing...
Old Jan 27, 2006 | 12:34 PM
RA11325's Avatar
RA11325
retarding timing will get you less power, typically you make power by advancing your iginition timing.
RA11325's Avatar
RA11325
Old Jan 27, 2006 | 12:46 PM
raptorbh12's Avatar
raptorbh12
i know that, but im saying i shouldnt have lost 13 hp by retarding the timing, and then theres the UR crank pulley i added since i last dynoed. so its more like i lost 20hp from retarding the timing, or something else unforseen is wrong.
Old Jan 27, 2006 | 01:08 PM
zzzya's Avatar
zzzya
Depending on the amount of timing you have taken out, these results may not be suprising at all. I actually would have guessed around or a little less than stock. With a Utec and a proper tune you should be able to hit 265-268 is my guess. You are lacking headers, which would give you a big improvement.
Old Jan 27, 2006 | 10:10 PM
Dubai's Avatar
Dubai
Subscribing for Utec numbers. keep us posted
Old Jan 28, 2006 | 08:20 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
+1
Old Jan 28, 2006 | 09:56 AM
laswyguy's Avatar
laswyguy
subscribing
Old Jan 28, 2006 | 03:10 PM
NA350Z's Avatar
NA350Z
subscribing...
Old Jan 29, 2006 | 05:44 PM
titanjc's Avatar
titanjc
+1 on subscribing. Very interested in seeing these UTEC #'s.
Old Jan 29, 2006 | 08:03 PM
Three days since the OP and I don't see any charts. Am I missing something?
Old Jan 29, 2006 | 09:34 PM
titanjc's Avatar
titanjc
Maybe the fact that the OP said that he will have the UTEC installed Monday?
Old Feb 1, 2006 | 04:40 AM
zpeed350's Avatar
zpeed350
subscribing...
Old Feb 1, 2006 | 05:03 AM
BobbyRitz's Avatar
BobbyRitz
I picked up 14whp after UTEC tuning. I had the AAM reflash prior to adding UTEC.
Here's the list of mods during UTEC tuning:
AAM polished plenum
AAM plenum spacer
AAM y-pipe
AAM 2.5" test pipes (currently off)
AAM 3" single stainless angled exhaust
AAM ECU flash
UTEC with Tuner Reg Pro
Injen RD CAI
ACT clutch w/ 6 puck Race Disc
Fidanza flywheel
Here's part of my post from 350z - tech:
OK. The results are in. The baseline dyno run was 253whp / max torque 239. UTEC installed and tuned with 93 octane - 264whp / max torque 248. UTEC installed and tuned with 100 octane - 267whp / max torque 251.
I thought that I would get more out of adding UTEC to my NA setup. I'm not unhappy, the setup might just require more tuning and adding UTEC was a part of my plan to go FI next year anyway.
I feel that the stock cats might be too restrictive. If I had my test pipes on, I might have put 270whp down using 93 octane.
I was suprised that the gains were minimal when using 100 versus 93 octane. I believe that the timing was advanced 2-3 degrees on 100 octane. I'll check to be sure. Also, I'm not sure that the car was empty after the 93 octane tuning. This could have resulted in 95-96 octane fuel after the 100 octane was added.
_______
It's my opinion that we will only get 15-20whp out of UTEC while NA. UTEC comes to life when added to an FI application.
Considering that I will be going FI later this year, adding UTEC was a worthwhile purchase.
My 2 cents.
Old Feb 1, 2006 | 06:19 AM
GAaaAR's Avatar
GAaaAR
AAM polished plenum
AAM plenum spacer
AAM y-pipe
AAM ECU flash
Injen RD CAI
Fidanza flywheel
_______
My 2 cents.
Sounds about right. I looked at your mods and tried to guess how much wheel hp you would have after utec tuning without looking at your results. I actually guessed 263 whp on 93 octane while you made 264 whp. So i was close.
Old Feb 1, 2006 | 07:57 AM
Beta99's Avatar
Beta99
The UTEC also showed similar results on my G35 cpe
-from stock i picked up ~12whp
-after adding the LMS res. test pipes and a tune, i picked up another 12whp
It's definitely worthwhile w/NA and a MUST w/FI.
