Scott Performance custom grind cams or Nismo Cams. please help CANT DECIDE!!!!
Old Feb 2, 2006 | 07:54 PM
chichi506's Avatar
chichi506
Smile Scott Performance custom grind cams or Nismo Cams. please help CANT DECIDE!!!!
i would just like to know the specifications of both of these cams. if anyone has these cams on their car please feel free to comment. i really can't seem to decide between the two of these. any input is much appreciated. thanks!
Old Feb 2, 2006 | 08:04 PM
ZON's Avatar
ZON
Scott Perwho???
Old Feb 2, 2006 | 08:11 PM
287HP's Avatar
287HP
Nismo Cams:262 Duration with 10.2 mm of Lift
JWT S1 CAMS: 260 Duration with 10.9 mm of Lift
Scott Perf. Custom Grind: NA
Old Feb 2, 2006 | 09:21 PM
XBS's Avatar
XBS
Veteran
I am going with scott performance as of now....
XBS's Avatar
XBS
Veteran
Sorry, dont know if your car is turbo, these are designed for turbo cars not NA cars...
Old Feb 2, 2006 | 09:31 PM
ZON's Avatar
ZON
No, he has N/A cams also.
Old Feb 2, 2006 | 09:48 PM
chichi506's Avatar
chichi506
if i go with the N/A cams, that means that i won't be able to use it if i ever decide to go f/i? does that mean i should just wait on the cams as of now? and was also wondering what the gains were if any of you know. thanks
Old Feb 2, 2006 | 10:24 PM
ZON's Avatar
ZON
You can still use the n/a cams and you'll be good for FI.
Old Feb 2, 2006 | 10:40 PM
287HP's Avatar
287HP
+1
Old Feb 2, 2006 | 10:46 PM
Vick781's Avatar
Vick781
Ted is the man!
Old Feb 2, 2006 | 11:24 PM
steela2110's Avatar
steela2110
go with the scotts performance cams!
Old Feb 3, 2006 | 12:09 AM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
IMO...if you are even considering going F/I in the future, I'd wait until then since they'll have your engine pulled out anyway for the install. This will save you some money & as you know, cam installs are not cheap. But if you still want do it anyway, I'd definitely recommend getting a fuel/engine management system like unichip or even a TS reflash in order to fully utilize those cams.
Old Feb 3, 2006 | 04:23 AM
arizzee's Avatar
arizzee
Nismo R-Tune cams are .426" lift = 10.82mm
JWT S1 cams are .428" lift = 10.87mm
Old Feb 3, 2006 | 06:22 AM
chichi506's Avatar
chichi506
i have the unichip, and it was tuned by ted. i definetely felt a difference when it was installed. but with cams, i'm pretty sure it'll turn into a screamer! lol
Old Feb 3, 2006 | 08:27 AM
JamMasterW's Avatar
JamMasterW
how much are the scott performance cams running for???
Old Feb 3, 2006 | 09:40 AM
287HP's Avatar
287HP
You will probably remember older posts where everyone thought the Nismos were 10.2 mm of lift, but no one seemed to calculate .426" to mm correctly. Thanks for the clarification. So it looks like the Nismos & JWTs are nearly identical. FWIW-The stock cam specs(non-rev-up) come in around 9.5 mm with 238 IN & 240 EX Duration, although I have heard of them being around 9.2 mm of lift
Old Feb 3, 2006 | 12:32 PM
ZON's Avatar
ZON
All excellent points to consider.
Old Feb 3, 2006 | 12:35 PM
ZON's Avatar
ZON
i have the unichip, i definetely felt a difference when it was installed. but with cams, i'm pretty sure it'll turn into a screamer! lol
This is true, as I and I am sure 287HP can concure.
Old Feb 3, 2006 | 12:46 PM
287HP's Avatar
287HP
+1
Zon,
You should ask ted what the specs are on those cams, I am real curious as to what they are.
Old Feb 3, 2006 | 02:36 PM
chichi506's Avatar
chichi506
he's quoting for the cams $1600 installed. but with an extra 800, bringing the total to 2400, i can have titanium valve springs and have my car be able to rev upto 8000 rpms no problem.
