ebay engine torque damper
Old Feb 9, 2006 | 12:27 AM
bleunetizen's Avatar
bleunetizen
dscheers: Do you have any picture of your installed damper? It would be great if you could share your picture
overZealous1: What kind of driving do you do with your Z? I wonder if chasis wont be bent/twisted/deformed/cracked and etc since the chasis will have to take the majority of engine vibration? I wish to know if this solid mount could be harmful in long term basis?
Thanks!
Old Feb 9, 2006 | 06:07 AM
DomZ's Avatar
DomZ
As long as the install isn't too bad I'm definately game for theses....hopefully it will allow me to hook up my stock strut bar again with my AAM spacer....
Old Feb 9, 2006 | 08:01 AM
MustGoFastR's Avatar
MustGoFastR
Interested... Always game for better throttle response as long as install isn't too difficult. Could it be a DIY in the garage with jack stands? How can you lift the motor enough for install at home?
Old Feb 9, 2006 | 08:21 AM
overZealous1's Avatar
overZealous1
Thanks!
i have been running mine for about 6 months. no probs at all. there will be no probs at all concerning the chassis. these would be a must have for anyone doing ANY type of competition. cheap way to remove some drivetrain losses and add predictibility to throttle responces. also very well suited for daily drivers that can tell the difference it makes. like i said, i use a thin set of rubber washers, and that helps a little for the vibration and not lose any of the effects.
Old Feb 9, 2006 | 08:24 AM
overZealous1
you could lift the engine with a jack under the motor to lift it. just need to support it correctly and make sure not to damage the oil pan. in that situation, just do one side at a time. i will look at what it would take to do. getting the factory mounts out would be the prob cause they are so big around. would prolly be a big help to remove the tire to gain some access in the mount area.
Old Feb 9, 2006 | 11:07 AM
bleunetizen
great, i am sold.. as long as the price isn't too high!
Old Feb 9, 2006 | 11:32 AM
gringott's Avatar
gringott
Sounds fantastic.
Old Feb 9, 2006 | 11:35 AM
MySunset350Z's Avatar
MySunset350Z
what i like about it is that i can get the full plenum spacer with the stock bar.
eta on the price? and will it include detailed insructions with pictures?
Old Feb 9, 2006 | 12:25 PM
dscheers's Avatar
dscheers
Here's the pics I got from who the seller of my Engine Damper. Hope this helps.
(please note, this is not my car)
Danny
Attached Thumbnails ebay engine torque damper-enginedamper1.jpg   ebay engine torque damper-enginedamper2.jpg
Old Feb 9, 2006 | 04:46 PM
overZealous1
wasn't able to make it to my car today to check out install. should make it tomorrow.
Old Feb 9, 2006 | 05:16 PM
nearly zer0's Avatar
nearly zer0
Subscribing.
I loved the improvement stiffer motor/tranny mounts made in my vr6 and wrx. I would love a set for my z!
Old Feb 9, 2006 | 05:25 PM
overZealous1
man if i knew there was going to be such an interest, i would have made them alot sooner, lol!!
Old Feb 9, 2006 | 06:30 PM
overZealous1
ok, price is set, $115 shipped. will start another thread to answer other questions on this. thanks.
Old Feb 10, 2006 | 04:55 PM
bleunetizen
dscheers: Thank you for the pics! How would you rate your engine damper? Any good/bad about it?
Old Feb 10, 2006 | 06:37 PM
dscheers's Avatar
dscheers
Nothing bad.
Good: engine tilted notably less on the dyno runs after installed, which should give a (tiny) bit more torque...
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
