R34 transmission on 350z?? is that possible??
Old Feb 13, 2006 | 05:36 PM
350z-900whp's Avatar
350z-900whp
Default R34 transmission on 350z?? is that possible??
do you think guys,it possible to get R34 transmission on 350z with vq35de-tt engine??
if that will work we can fix all of our traction problems..
i saw that 350z with R34 transmission (i'm not sure if it has a R34 engine also) from top-secret
Old Feb 13, 2006 | 05:45 PM
jakesford's Avatar
jakesford
i think they had an RB motor attached to it lol
Yeah in their gallary they have two Z's with RB26 motors one RWD and the other AWD
They have VK45 G35 and some other "slow" cars
Old Feb 13, 2006 | 06:30 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Yea dude, it's like a 2 hour swap. Costs like 70 bones....schweeeeet!
Old Feb 13, 2006 | 06:43 PM
350z-900whp
yeah did you see the mini van
Old Feb 13, 2006 | 11:19 PM
350z-900whp
i was wondering how we could mount in the front differential? and what about the drive-shaft??
Old Feb 14, 2006 | 03:23 AM
PoWeRtRiP's Avatar
PoWeRtRiP
you mean drive shafts? and what about the half shafts? of the cv joints you will install? tranny mounts? adaptor plate? tranny computer? front diff (i assume it has one)? shifting assembly?
this would be a big pain in the ***...have you ever tried converting a car to awd before? its not easy at all.
Old Feb 14, 2006 | 04:23 AM
350z-900whp
yes, that what i mean.
what i have convert 2wd SUV to 4wd , but not a car to 4wd.
i think it would be a lot harder than suv but still same concept right??
Old Feb 14, 2006 | 06:00 AM
PoWeRtRiP's Avatar
PoWeRtRiP
sure same concept. but a much bigger pain in the ***. it will cost a lot of money to do this.
i have seen several "attempted" FWD-->AWD coversions on a 2g eclipse. not one has succeeded. most just say F it when they realize the cost involved.
Old Feb 14, 2006 | 06:15 AM
350z-900whp
what would it cost me approximate??
but don't you think it's worth it
i mean what's the benefit from increasing the horsepower with out traction
Old Feb 14, 2006 | 06:44 AM
PoWeRtRiP's Avatar
PoWeRtRiP
i have no idea of the cost. but you will need the following fabricated
-driveshaft(s) there are more than one. usually its a four piece driveshaft in awd trannies
-tranny mounts
-cv shafts (might be able to use R34 ones, but dont know)
-adaptor plate for the flywheel to the tranny
on top of that u need a tranny out of an R34. not sure of the cost but id expect at least 1k with freight and all that.
then you need to install it all. this will involve cutting, welding, and generally be a pain in the butt.
it will cost several thousands of dollars to do this.
you can also increase traction by suspension mods, bigger tires, better tires, and gearing. look at your other options first before you turn your car into a huge money pit.
Old Feb 14, 2006 | 07:18 AM
350z-900whp
i know that but am checking all of these TT Z's with no traction?? there losing races against those crappie cars . cause of traction.
i'm now installing my own PE-TT with other modes. hope that wouldn't have a huge traction problem.
thanks for these valuable info
Old Feb 14, 2006 | 08:56 PM
2slo2bfurious's Avatar
2slo2bfurious
Just throwing in an idea... what about the Awd from a g35x or another model?
Old Feb 14, 2006 | 09:12 PM
350z-900whp
you mean the FX35?? or what??
Old Feb 15, 2006 | 12:37 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
I have ZERO traction issues and I'm near 500whp....you don't need AWD...you just need a good tire and suspension setup.
Old Feb 15, 2006 | 08:57 AM
350z-900whp
i have JIC-flat A2 and sawybar will that be it...? with good tire's??
i have 19inch rims so what would be a good tire's to get??
and if there is non good tire's for 19 , what is then the best chose for 17ome rims??
Old Feb 15, 2006 | 09:47 AM
PoWeRtRiP's Avatar
PoWeRtRiP
bfg drag radials, goodyear eagles, yokohama advans, any of the super sport tires.
your pickings will be slim in 19" but there are a few options. are you running a 9" or 10" wide rim? put the biggest piece of rubber you can on the back (may have to roll fenders) and youll be ok.
Old Feb 15, 2006 | 10:53 AM
03boostedZ's Avatar
03boostedZ
I would recommend the Mickey Thompson Drag radials. If you get these, with your supsension and you still have traction problems than you just need to drive. I myself run these and several friends in the 500+ hp range and have no issues with traction.
Old Feb 15, 2006 | 02:24 PM
350z-900whp
with 19inch
is it daily use or just for the drag-race?
Old Feb 15, 2006 | 04:10 PM
jinsei888's Avatar
jinsei888
Ban!!!!
Old Feb 15, 2006 | 06:18 PM
liudacris's Avatar
liudacris
so what is your tire and suspension setup?
