R34 transmission on 350z?? is that possible??
Old Feb 15, 2006 | 08:56 PM
jakesford's Avatar
jakesford
if your running 19"s with street tires = no traction from a dig
you don't need AWD for traction out of the hole, the fastest vehicles from a dig street and strip are RWD with a correct suspension and tire...
You want the most sidewall you can get wether it be a DR or slick... If you have non-brembro brakes then you can fit some 15" drag wheels such as welds and then slap on some DR's or ET streets and you'll be able to hook... atleast untill you break a half shaft
Old Feb 15, 2006 | 09:04 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Originally Posted by liudacris
so what is your tire and suspension setup?
295/35-18 BFG Drag Radials, Nismo S-tune suspension (not TOO stiff...still plenty of suspension travel), traction bars, alignment tweaks in the rear.
I'm pretty sure I could still hook almost 100% with an agressive sport tire like a BFG KD or Toyo T1S, etc.
Old Feb 16, 2006 | 08:52 AM
03boostedZ's Avatar
03boostedZ
Originally Posted by 350z-900whp
with 19inch
is it daily use or just for the drag-race?
Wasnt implying drag radials for a 19in tire. i keep a set of 300zx wheels for my drag radials. I run 255/50/16 M.T. drag radials and couldnt be happier. id recommend that size or 275/40/17's for us Z boys.
Row2K
North East Marketplace
Dec 27, 2015 12:09 PM
bcoffee20
Nov 19, 2015 06:39 PM
seagrasser
Oct 11, 2015 03:27 PM
hardkicks
Sep 20, 2015 12:28 PM
