Why am I hearing a sloshing liquidy sound??
Old Feb 23, 2006 | 03:16 PM
BENJ-AMG's Avatar
BENJ-AMG
Default Why am I hearing a sloshing liquidy sound??
I can hear it most often when the car is cold. It seems to be coming from somewhere around the footwell or right behind the firewall just below the left side of the steering column. I have NO idea.
Old Feb 23, 2006 | 04:10 PM
first350's Avatar
first350
maybe the AC? there's a hose that drains the water accumlation from your AC unit...the drain hose can get clogged and keep the water in the HVAC piping - if you lift up your car, there'll be a small hose that you can spray compressed air into to unclog it.
Old Feb 23, 2006 | 04:18 PM
Vamos_Rafael's Avatar
Vamos_Rafael
my sloshing sound is the gasoline in the tank sloshing around...
did you de-spare your car?
if so there will be sloshing...
Old Feb 23, 2006 | 07:10 PM
BENJ-AMG's Avatar
BENJ-AMG
Well, it's coming from up front so it's not the gas tank. The AC line sounds plausible. Any pics of the hose you're talking about?
Old Feb 23, 2006 | 07:33 PM
DayBlueZ's Avatar
DayBlueZ
Sound like water running through a sewer pipe? Is it at crank up and when you rev it stops?
Old Feb 23, 2006 | 07:52 PM
G352NV's Avatar
G352NV
Heater hose? I hear it sometimes. The heater hose goes through the firewall.
Old Feb 23, 2006 | 08:47 PM
BENJ-AMG's Avatar
BENJ-AMG
Yep. What is it?
Old Feb 23, 2006 | 08:59 PM
G352NV's Avatar
G352NV
Water...
Old Feb 23, 2006 | 09:11 PM
Bboy Hustler's Avatar
Bboy Hustler
bodily fluids??
hahahah
Old Feb 24, 2006 | 01:58 AM
DayBlueZ's Avatar
DayBlueZ
Did you just put on a plenum or do something with the cooling system?
Old Feb 24, 2006 | 07:19 AM
DomZ's Avatar
DomZ
Well, I have the exact same issue as you, but I couldn't quite figure where it was coming from. I usually can hear my gas slosh around but this was before I left my driveway...
Old Feb 24, 2006 | 07:27 AM
michaeljr6's Avatar
michaeljr6
check your coolant to see if it's full.....
Old Feb 24, 2006 | 07:31 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
ive got the same slosh on cold start ups......
i have de-spared and i have a plenum spacer.
going to check my fliud level...
Old Feb 24, 2006 | 07:49 AM
SB04's Avatar
SB04
I get the same noise in my wife's '04 Maxima and found this in the Maxima TSB's...sounds like the same issue
http://nissanhelp.com/Ownership/Bull.../NTB03-072.htm
Old Feb 24, 2006 | 10:21 AM
DayBlueZ's Avatar
DayBlueZ
Yup, that's what it is. If you have air in the system it sounds like it's water running through a pip right in front of you. You have to bleed it out. You may also notice that when you come to a stop the heater is less efficiant.
Old Feb 24, 2006 | 10:43 AM
BENJ-AMG's Avatar
BENJ-AMG
Ok so that's what it is. Is there any potential damage that could occur if I dont bleed the line?
Old Feb 24, 2006 | 11:33 AM
first350's Avatar
first350
I'm not sure about the Z, but I've heard of some cars that if you don['t properly flush/refill the cooling system, a air pocket can develope that can cause localized heating...if this occurs within the engine block, it could cause warping and bad things can happen!!
Old Feb 24, 2006 | 01:05 PM
DayBlueZ's Avatar
DayBlueZ
I don't think so, but, anything is possible. Mine has been doing it for 4-5 months. I'm too lazy to bleed it.
Old Feb 24, 2006 | 02:02 PM
JDMFairlady21's Avatar
JDMFairlady21
wow i've been experienceing it too for the longest... shoot gotta bleed those lines then.
Old Feb 24, 2006 | 08:57 PM
Nexx's Avatar
Nexx
omg, you are dead on, i have both symptoms! take to take her in! sigh.
