How long does the stock clutch last?
Old Feb 28, 2006 | 07:42 AM
Hypnoz's Avatar
Hypnoz
Default How long does the stock clutch last?
For normal drivers? I realize the more you beat on it, the less time it will last. If I buy a used Z, is there any way to tell if the guy beat the crap out of it or not?
The search function does not seem to be working...
Old Feb 28, 2006 | 10:23 AM
Hypnoz's Avatar
Hypnoz
Anyone?
Old Feb 28, 2006 | 11:42 AM
PoWeRtRiP's Avatar
PoWeRtRiP
depends entirely on the driver. there is no life expectancy. you can measure the amoutn of play in the clutch to get an idea of how much material it has left.
Old Feb 28, 2006 | 01:25 PM
Hypnoz's Avatar
Hypnoz
hmm, do you mean like it will catch higher and higher up, or do you mean if theres problems with RPMS and the car not going as the rpms go up?
Old Mar 2, 2006 | 10:42 AM
Hypnoz's Avatar
Hypnoz
eh?
Old Mar 2, 2006 | 10:53 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Hypnoz, we meet again
Anyways, I own an 05 so my clutch and car are pretty new. However, none of the used car buyers that post up in the forums have ever said anything about their clutch being worn out to my recollection.
Alberto has raved about the stock clutch over and over again. It is a very good clutch as long as the driver is not totally insane or idiotic... it can slip a LOT without burning. (Judging burning by the smell) I've only burned it once to my recollection, that was while backing up slowly on a steep hill for like 200 yards because I had to get out of the way of a huge truck. Even some crazy launches I've done, which weren't the most artful/skillful, did not result in a burning smell.
It wouldn't be my first concern if I were looking to buy a used Z. Just have a small account of $2-3k that you keep seperate for incidentals on the car and if worst comes to worst, you can buy a new clutch. Most likely you'll end up replacing the rotors/brake pads way before the clutch anyway.
Old Mar 3, 2006 | 01:49 PM
Hypnoz's Avatar
Hypnoz
Thank's Wired. My only concern is that if i buy a Z with 40k+ miles.... then I should be worred perhaps?
Old Mar 4, 2006 | 03:57 AM
streetracer's Avatar
streetracer
I don't know why you should be worried. My car has 60k miles and is like new. I take great care of the vehicle, even though I drive it pretty hard most of the time. I think your concern should be the previous owner and how he took care of the car.
Old Mar 4, 2006 | 04:05 AM
n8vz's Avatar
n8vz
With "normal driving", most clutch will las about 75~100K miles.
My friend had a Camry 5MT who drove his OE clutch to about 180K miles before replacing it. (it was slipping pretty bad towards the end)
Old Mar 5, 2006 | 10:24 AM
Dissolved's Avatar
Dissolved
Should last til at LEAST 60-80k miles with semi-spirited driving. I have 45k and no probs.
To test the clutch of a car you may buy, put it in a high gear and step on the gas. If the RPMs rise (rev up ) and the car doesnt move, clutch is toast.
Old Mar 6, 2006 | 12:29 PM
KuyaEasy's Avatar
KuyaEasy
I'm at 30k miles on my stock Z (3yrs old). Driven moderately and the clutch is still good.
Old Mar 6, 2006 | 12:50 PM
ANXIOUZ's Avatar
ANXIOUZ
Bad clutches seem to follow people. There are some Z owners who have gone through several clutches in only a year or two. Certain drivers seem to wear down clutches faster than others.
Test drive the car...you'll know if there is something wrong. If it drives fine then the clutch is prob fine. Treat it right and you'll be OK.
Old Mar 6, 2006 | 03:02 PM
D15na's Avatar
D15na
... glazed it the perferred term... happen'ed to my '04 touring after 32k.. clutch seems to be a lil better after it warms up also.
Old Mar 6, 2006 | 03:25 PM
jakesford's Avatar
jakesford
i've got 53K on my stock clutch, and I don't baby the car... a 3rd gear powershift still gets the car loose.
Old Mar 7, 2006 | 12:38 PM
chaparro78's Avatar
chaparro78
I have a Vortech S/C with 9lbs of boost and have had it for over 25Kmiles (car has 46kmiles) and have been running the stock clutch the entire time. Works great
Old Mar 7, 2006 | 01:21 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Pulled mine out at 53K with thousands of powershifts, 6000rpm clutch drops and anything else you can imagine. Never 1X slipped, and still chirped 3rd like it was new.
Old Mar 8, 2006 | 07:05 AM
Jay'Z's Avatar
Jay'Z
i have my stock clutch in storage and i expect if it stays there it would last a lifetime...... jk
Old Mar 8, 2006 | 09:10 AM
Hypnoz's Avatar
Hypnoz
Good things, thanks for the replies fellas. Much appreciated.
sherm
Apr 11, 2020 05:21 PM
