AT 3.5 Pumpkin Swap Reliability
Old Mar 13, 2006 | 01:06 PM
CTBZR's Avatar
CTBZR
Default AT 3.5 Pumpkin Swap Reliability
I found a MT 3.5 VLSD pumpkin for my AT. I wanted to hear from the folks who did the swap. Have you experianced any reliability issues with the AT having the 3.5 gearing?
My 350Z is my daily driver and need to know if I should swap it out...
Any feedback is greatly appreciated.
Old Mar 13, 2006 | 05:10 PM
bigo109's Avatar
bigo109
I had mine swapped out a month ago. No problems so far. Pulls hard. Still good for a daily driver.
Old Mar 13, 2006 | 05:14 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
keep in mind, you will loose your high end. For example, when runing 80miles/hour, your RPM was 3000, now it will be 3200-3300. I'll swap my next month too.
Old Mar 13, 2006 | 06:14 PM
roneski's Avatar
roneski
I've had mine swapped for nearly a year, no problems at all. You'll lose your cruise control though, but I never used it anyways.
Old Mar 13, 2006 | 06:15 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
oh shiet..why is that?
Old Mar 13, 2006 | 06:26 PM
stereoneeds's Avatar
stereoneeds
really? i did mine a few months back, and i still have my cruise control. everythings perfect so far, and i love it. feels way quicker off the line.
Old Mar 13, 2006 | 06:29 PM
roneski's Avatar
roneski
I'm not sure why it is. It only seems to happen on the highway for me, I suspected that it had something to do with the manufacturer not wanting you to engage the cruise control at high speeds, but who knows.
I've heard of several other people having the same problem, this would actually be the first time I've heard of someone not having that problem.
I've got an '04 (not '04.5) G35 coupe btw.
Old Mar 13, 2006 | 06:31 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
hummm..i have cruise control at 80 to 90 miles/hour all the time. But you have G35. That might be the reason?
Old Mar 13, 2006 | 06:33 PM
roneski's Avatar
roneski
Most likely a difference between the older and newer ECUs. What year is yours?
Old Mar 13, 2006 | 06:45 PM
booger's Avatar
booger
I have the 3.5 in my 03 G35 . I lost cruise control . Well I can set it once and it will hold , but if I tap the brakes for traffic . It will not set again till I shut the car off . I think its because the rpm's are out of range for what the ECU is used to or set for at that speed
Old Mar 13, 2006 | 08:00 PM
zzzya's Avatar
zzzya
I have had the 3.5 FD in my 03 350Z for quite a while and many miles, long trips, very fast speeds and so forth. Cruise works perfectly and really no issues at all to speak of. I think this FD actually takes some load off the rest of the drivetrain and even though rpms are up a bit, in the long run may increase drivetrain longevity.
Old Mar 13, 2006 | 08:09 PM
mgl's Avatar
mgl
i'll have mine on saturday. i'll let ya know how it goes.
Old Mar 13, 2006 | 08:12 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
rpm up, isn't that your engine work harder = reduce?
Old Mar 13, 2006 | 08:42 PM
bigo109's Avatar
bigo109
cruise control still works on mine. I have an 03 enthusiast.
Old Mar 13, 2006 | 09:21 PM
BluZee's Avatar
BluZee
Ive had mine for about a year now. No issues. Cruise controls works fine.
Old Mar 14, 2006 | 01:41 AM
evobunny's Avatar
evobunny
sorry newbie question. what are the pros and cons of the swap
Old Mar 14, 2006 | 03:03 AM
zzzya's Avatar
zzzya
Not necessarily. You are effectively reducing the amount of load on the drivetrain, much like reducing the weight of the car. If you do a lot of stop and go driving you will most likely reduce overall wear. If all you do is highway driving then the slight increase in rpms may overcome that benefit and be more of a negative. I can't believe that a few hundred rpm difference would yield that much of a problem down the road, but I may be wrong. Also, depending on where your rpms end up on the road and how your torque curve looks, you could actually be running at an rpm where the engine is more efficient and reduce overall gas mileage which may even increase the overall life of the drivetrain.
Old Mar 14, 2006 | 10:42 AM
CTBZR's Avatar
CTBZR
Thanks folks...
Getting mine delivered this week. Should be in my hands by this wekend...
1973camarolt
Drivetrain
Oct 11, 2015 01:26 PM
Fixxxercask
Drivetrain
Sep 28, 2015 11:15 AM
SharX59
Sep 27, 2015 09:23 AM
