Weird noise at 80mph and above
Old Mar 14, 2006 | 11:08 AM
97supratt's Avatar
97supratt
Default Weird noise at 80mph and above
Hey guys,
I am hearing a weird noise at speeds 80+mph. It sounds like a humming or whistling noise. I know its not the transmission because I put it into neutral and it didnt go away. I noticed it did go away once I decreased my speed below 80mph. Anyone have an idea?
Old Mar 14, 2006 | 11:19 AM
Starchecker's Avatar
Starchecker
Might be a bearing going bad.
I had something similar, it was from about 45 - 75 mph. Replaced the left front wheel bearing(I had hit a curb) and it went away. I actually thought it was some tire noise, but it made a droning noise.
Old Mar 14, 2006 | 11:28 AM
JCat's Avatar
JCat
When Nissan replaced my tranny, they left one plastic snap off of a plasic shield. At high speed, it vibrated.
Jack it up and look for loose plastic pieces underneath or in the wheel wells.
Old Mar 14, 2006 | 11:32 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Tires feathering, wearing out unevenly? Check the front tires, sounds like it to me. At first I thought your diff was whining but if you put the car in neutral and it stayed its not that...
Old Mar 14, 2006 | 11:57 AM
97supratt's Avatar
97supratt
Its a 06 with 3300 miles, I put new g35coupe wheels and brand new rubber on 500 miles ago. I'm sure its not feathering but i'd like to really figure out what it is. Its either the rear diff or bearings.
Old Mar 14, 2006 | 12:30 PM
ASTIG_Z's Avatar
ASTIG_Z
I have this issue as well....subscribing
Old Mar 14, 2006 | 12:34 PM
barthelb's Avatar
barthelb
Master
Question
Maybe they didn't mount the tires in the correct rotation or worse put a rear tire up front with a front tire?
Old Mar 14, 2006 | 02:18 PM
97supratt's Avatar
97supratt
It isnt mounting or rotation because the noise came 500 miles after I put wheels and tires. If it was a mounting and rotation problem i'm sure I would have heard it when I first took it out. Plus I checked all the wheels and tires and they are installed correctly.
Old Mar 14, 2006 | 02:26 PM
plumpzz's Avatar
plumpzz
Is it mechanical noise or is it like wind creeping in thru holes?
Old Mar 14, 2006 | 03:40 PM
97supratt's Avatar
97supratt
Its mechanical for sure. Its a weird humming, rotational noise. I really think its my diff. I'll have nissan check it out when I take it in for a trans replacement this week.
Old Mar 14, 2006 | 05:37 PM
shifty711's Avatar
shifty711
I have a whining noise from my diff at about that speed. If i let go of the gas it will stop, but if I hold the gas at around 80mph it will whine the whole way. Im not really concerned about it though. Should i be?
Old Mar 14, 2006 | 06:05 PM
97supratt's Avatar
97supratt
Yeah thats the same exact noise except if i press the gas it goes away or if I go under 80mph.
Old Mar 14, 2006 | 07:10 PM
mdracer76's Avatar
mdracer76
wow.. same problem here too.. I think its a bearing... on my front right tire.. to much Dooorrrifto! LOL
Old Mar 14, 2006 | 08:10 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Originally Posted by 97supratt
Hey guys,
I had a very similar noise (howling) in my 2004 G35 tranny even when the clutch was pushed in. Neutral didn't make a difference. They said it was some type of brass thrust bearing going out. Dealership replaced the tranny and the noise is gone, but I don't like the new tranny. Shifting is chunky and somehow... not symmetrical.
Sorry to hear you are having problems like this so early in such a new car.
Unfortunatly, its a roll of the dice that seem a little too common.
Old Mar 15, 2006 | 08:11 AM
97supratt's Avatar
97supratt
The MREV makes up for it though!
Old Mar 16, 2006 | 04:47 AM
Z CRUZN's Avatar
Z CRUZN
Bingo - I'll bet it's your diff. If the backlash on the shims is loose, it'll make the sound you're describing. The diff will run cooler that way however. I had it set up that way with my 350evo 3.9 install.
Old Mar 16, 2006 | 08:07 AM
97supratt's Avatar
97supratt
The backlash on a stock diff would be out of specs? I hope not, lol . It started recently, its very weird but i'm sure its my diff.
Old Mar 16, 2006 | 08:16 AM
barthelb's Avatar
barthelb
Master
My old diff was howling, like a wooo wooo woooo at about 80 when there is no throttle applied, with your mileage it would seem not likely but the symptoms you have seem like that is your diff.
Old Mar 16, 2006 | 09:33 AM
97supratt's Avatar
97supratt
Well it is a nissan, .
Obadabot
Jun 18, 2023 11:31 PM
Uriyo_
Sep 8, 2021 08:46 AM
kyin
Oct 15, 2015 05:54 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
