guage wires?
Old Mar 22, 2006 | 04:42 PM
PumpedVA's Avatar
PumpedVA
Default guage wires?
ok installing a new guage pod to replace my cheap overlay one but the new pod location is higher than the overlay one and my guages will not reach the new pod location. whats a easy way to make them longer? can I splice them? if so what wires would I need?
Old Mar 23, 2006 | 02:15 AM
zachcrosen's Avatar
zachcrosen
For the power wire on my AEM Wideband, I just used a slightly larger diameter speaker wire. Been working great for close to 2 years now!
Old Mar 23, 2006 | 02:22 AM
Mike Wazowski's Avatar
Mike Wazowski
I would match the wire gauge that is currently on the gauges. You can go to any decent electronics store and get good wire.
Old Mar 23, 2006 | 06:40 AM
dream724Z's Avatar
dream724Z
Since this was posted in the engine room, one vital specification to consider is temperature range. The gages are up high behind the firewall so it is not a risk. Those wires just power the display motor current, and any 18gauge would be safe.
For any high temp wire application in the engine bay or near the exhaust do not use speaker wire. The insulation will degrade and could short out. I found super tough thermal coated wire by "Thermax" that could handle nearly anything.
Old Mar 23, 2006 | 08:56 AM
zachcrosen's Avatar
zachcrosen
My wires I used are just above the bottom of the dash and run to the power wire for my headunit. I DID NOT run speaker wire to anywhere in the engine bay! That is the ONLY wire I had to lengthen.
Old Mar 24, 2006 | 04:49 AM
PumpedVA's Avatar
PumpedVA
I just need to make them longer at the end where the guages are. I only need a extra 6" or so
Old Mar 24, 2006 | 04:57 AM
Mike Wazowski
just get some wire at radio shack or something. I would match up the colors to avoid confusion in the future, but that is just me. I am **** like that.
350Z_Al
Oct 29, 2020 07:44 PM
bcoffee20
Nov 19, 2015 06:39 PM
nanotech
Oct 2, 2015 05:02 AM
cashmoney03
Sep 27, 2015 05:24 PM
Beater350z
Sep 9, 2015 03:36 PM
