Should I be worried?
Old Apr 5, 2006 | 06:26 PM
03_Track_Z's Avatar
03_Track_Z
Default Should I be worried?
I have an intake, resonators (instead of cats, so basically test pipes), x pipe, mufflers, 2.5" piping, and am soon getting headers and a plenum spacer.
The reason I have those resonators is because the aftermarket cats I put on blew out, and so I think that may be because my mixture is off but I have no clue.
So... should I be worried given the mods I have and am going to soon have, and also with that happening to my cats? Is my AFR dangerously off?
Old Apr 6, 2006 | 05:57 AM
03_Track_Z's Avatar
03_Track_Z
pleeease someone give me advice
Old Apr 6, 2006 | 10:56 PM
03_Track_Z's Avatar
03_Track_Z
ttt
Old Apr 6, 2006 | 11:01 PM
plumpzz's Avatar
plumpzz
if ur NA, dont worry. How did the X pipe change ur tone? Less rasp aswell?
Old Apr 6, 2006 | 11:18 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Once you put all those breathing mods on I'd get an ECU flash at the least, or a UTEC and tuning at the most.
Old Apr 7, 2006 | 03:21 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
your AFR might barely be off but nothing to worry about, with those mods my AFR was 13.1-13.3 all the way across till 5000 and got richer....
just read up more and look at peoples dyno sheets and compare mods with their dyno graphs.
or simply buy a wideband so you know exactly what it is, there are plenty out there for around 300 that will tell you everything you need to know...
Old Apr 7, 2006 | 05:22 AM
03_Track_Z's Avatar
03_Track_Z
thanks guys, plumpzzz i dont know how it changed it because ive never had the exhaust on without the x pipe, but when i get the old blown out cats removed and the resonators installed im debating having them cut out the x pipe for a sec to see how it sounds, bc im curious but only if its really cheap to do and undo.
waldo36
Sep 20, 2015 09:13 PM
PureR3d
Sep 10, 2015 06:23 PM
ddegrande21
Sep 6, 2015 11:15 AM
RP-350Z
Jul 20, 2002 07:47 AM
