Problem with KJR pulley
Old Apr 5, 2006 | 07:59 PM
mucky's Avatar
mucky
Default Problem with KJR pulley
I took the Z to the dealer to have the recall fixed and have an oil leak checked out. They told me the oil leak is coming from the crankshaft seal. Could the pulley have caused this? I have put on about 5k miles with the pulley with no problems until last week. could the seal have been damaged when the pulley was installed? If so how.
Also, this will probally not be fixed under warrenty. Is it hard to replace? Can anyone tell me what's involved if I were to replace the seal myself.I haven't found out how much the dealer is going to charge me to fix the seal,but I just know they will bend me over if I have them fix it.
Thanks for your help,
Matt
Old Apr 5, 2006 | 08:27 PM
HarvesterUT's Avatar
HarvesterUT
can you put the stock pulley back on?
Old Apr 5, 2006 | 09:30 PM
mucky's Avatar
mucky
Yes. What do you have in mind?
Old Apr 5, 2006 | 10:04 PM
Nano's Avatar
Nano
if the pulley was installed wrong, yes it can damage the seal/engine/crank/etc..
Old Apr 5, 2006 | 10:12 PM
350z_this's Avatar
350z_this
check around... but never heard of it before......
Old Apr 6, 2006 | 04:57 AM
mucky's Avatar
mucky
How could it be installed wrong? Doesn't it basically just slide on.
mucky's Avatar
mucky
I don't understand
Old Apr 6, 2006 | 05:04 AM
Quamen's Avatar
Quamen
I would wonder how you could install it wrong also. I guess maybe if you torqued it wrong.
Old Apr 6, 2006 | 05:18 AM
Nano's Avatar
Nano
I meant old pulley removed properly and new one installed and torqued to proper specs. If it's not torqued properly it will come loose and damage the seal, there is atleast a couple of threads of people not torquing the pulley properly and ending up in your situation.
I don't see how a pulley could damage the seal otherwise. Beside someone installing it wrong
Search
Old Apr 6, 2006 | 08:18 AM
mucky's Avatar
mucky
Is it hard to change the seal? Is the torque spec still 36 ft/lbs?
Old Apr 6, 2006 | 08:26 AM
Yancy's Avatar
Yancy
Others have had the problem. Check out the North Central Forum here under the Detroit List page.
https://my350z.com/forum/showthread....101271&page=65
Old Apr 6, 2006 | 11:03 AM
HarvesterUT
OH HE||S NO! 36 ft/lbs on the instructions are WRONG! IIRC the proper spec is 36 ft plbs PLUS an additional 60 degreee turn. I think it's something like 100-120 ft lbs. i torqued mine to 120 ft lbs...no problems so far
Old Apr 6, 2006 | 11:09 AM
Nano's Avatar
Nano
exactly... here is the thread about the wrong instructions. Incidently, I was the one that pointed out the issue .
https://my350z.com/forum/engine-and-drivetrain/127868-kjr-pulley-installed-first-impressions.html
Old Apr 6, 2006 | 11:21 AM
SpeedRcr's Avatar
SpeedRcr
This is the only part I had the dealer put on...charged 50 bucks and the master tech I know popped it on with no problems...everything else I am comfortable doing...20k miles on it and no problems still
Old Apr 6, 2006 | 03:42 PM
MrKaira's Avatar
MrKaira
Really MrZ31
yeah if it isnt torqued down enough it can damage the seal, i had that problem... got a new engine now, shouldnt be a problem
Old Apr 6, 2006 | 06:29 PM
mucky's Avatar
mucky
My instructions didn't say anything about the extra 60 degree turn. Does anyone know what KJR would do for a problem like this, since it's their fault? I plan on contacting them tomorrow.
Can anyone tell how difficult it is to replace the seal?
Thanks,
Matt
Old Apr 6, 2006 | 08:01 PM
dream724Z's Avatar
dream724Z
Here are current instructions with spec'd torque values.
http://kjrperformance.com/docs/KJR%20350Z%20Crank%20Pulley%20Install.pdf#search='kjr%20pull eys'
On this forum someone found the crank seal for ~$10 and used needle
nose plyers to remove it and a wide driver to push in a new one.
You could go safe with a Fluidampr pulley (search).
Good luck!
Old Apr 6, 2006 | 11:44 PM
350z_this's Avatar
350z_this
did you want to sell me your kjr pulley?
Old Apr 7, 2006 | 09:30 AM
r10apple's Avatar
r10apple
Thanks,
Matt
I handle product-liability litigation claims here in Florida, but I am not an attorney. I'm also unfamiliar with Michigan law. That being said, if they printed incorrect instructions and you installed according to them, well, KJR should owe for any repairs.
Find your receipt; find your instructions; get your paperwork from Nissan over the seal, then contact KJR in writing and by phone to see what's what. Do not repair/replace anything further w/o documenting what has been done and taking pictures...
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
