Ultimate Racing VQ35 Heads
Old Apr 18, 2006 | 03:42 PM
  #41
Spanners's Avatar
Spanners
Having a quick look at the turbo specs of that kit (60-1 I belive)
You would have to be pretty big on the exhaust housing AR to get close to that sort of hp.
Injs are WAAAAAAAAAAAAAAY too small as is fuel pump.
What you runnign ECU wise?
Old Apr 18, 2006 | 03:43 PM
  #42
dscheers's Avatar
dscheers
Default Educational reads on head work
http://www.nissanperformancemag.com/september03/nerds/
http://www.nissanperformancemag.com/october03/nerds/
http://www.nissanperformancemag.com/november03/nerds/
http://www.nissanperformancemag.com/december03/nerds/
http://www.nissanperformancemag.com/january04/nerds/
Old Apr 18, 2006 | 03:56 PM
  #43
aalzuhair's Avatar
aalzuhair
The turbo will a 60-1 Hi Fi with a 62-1 wheel.
As far as the ECU I will be runing TurboXS UTEC
On the exhaust side I will be venting the WG and on teh exhaust I will have a VES system which basicly vents the exhaust under boost
As far as the injectors and fuel setup, why do you say they are way too small? If you would calculate fuel requirments based on a BSFC of 0.61 and IDC of 85% you would need 1000cc with an FPR of 1:1 ..... Could you please explain...
Old Apr 18, 2006 | 03:57 PM
  #44
Spanners's Avatar
Spanners
I will make no comment to the Author credability....
Name has been around for many years.
Old Apr 18, 2006 | 03:58 PM
  #45
aalzuhair's Avatar
aalzuhair
Thanks man looks like a good read
Old Apr 18, 2006 | 04:04 PM
  #46
Spanners's Avatar
Spanners
You state TURBO not TURBOS
Typo or you only have one? If one, no way in hell you're going to get there.
IIRC correctly, the kit comes with 380cc injs.
Most you'll see out them with a bump in base pressure is around 450-500hp atw.
Walbro 255... no comment.. 2x Bosch 044s would be my pic. 4.Xl/min at pressure each..
1000cc injs.. yes.. but I don't/didn't see that on your list
Old Apr 18, 2006 | 04:10 PM
  #47
aalzuhair's Avatar
aalzuhair
No, its TurboS .. .sorry ... and yes I will run 1000cc Peak and Hold using the stock ECU and the UTEC
I know the Walbros are not the best... but they have to do for now
Old Apr 18, 2006 | 05:31 PM
  #48
Spanners's Avatar
Spanners
Upgrade the pump/s and throw the UTEC away (sorry) and I think you're on the way to your targets.
Whats the AR and frame of the exhaust housing?
Exh wheels trim?
Old Jun 2, 2006 | 09:13 AM
  #49
q8pianist's Avatar
q8pianist
why throw the UTEC ????
Old Jun 2, 2006 | 09:16 AM
  #50
Zexy's Avatar
Zexy
Exh wheels trim?
Uhhh why throw the UTEC away???
Old Jun 2, 2006 | 01:01 PM
  #51
q8pianist's Avatar
q8pianist
cus UTEC is a CETUO :P ??
sales@czp
Sep 23, 2019 03:30 PM
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
