Powdercoating.
Old May 6, 2006 | 04:34 PM
abyss's Avatar
abyss
Default Powdercoating.
Can anyone explain how powdercoating is done and it it is possible to powdercoat engine components?
Old May 6, 2006 | 04:45 PM
drsifu's Avatar
drsifu
basically, the part you want to powdercoat is usually metal.
it is magnetized via an electric current that is applied to the piece in question.
powder is than sprayed on the piece. because of the current, the powder adheres to the piece in question.
the piece in question is than baked at a certain temp for a specified period of time which allows the powder to get baked on to the piece in question.
that is it. the piece essentially becomes slighter thicker than normal because of the powder.
yes, it is possible to powdercoat engine components. if you are talking about pistions and rings, than you cannot powdercoat those. if you are talking about other stuff, than yes.
there is a new technique to powdercoat plastics, but i won't go into that today.
good luck
Old May 6, 2006 | 05:00 PM
abyss's Avatar
abyss
good luck
Thanks
Old May 7, 2006 | 05:23 AM
SpeedRcr's Avatar
SpeedRcr
you can powdercoat plastics too...i had a stock grill powdercoated
Old May 7, 2006 | 05:24 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
I just dropped off my front timing cover for the built engine @ the powdercoaters. They have a chrome-like finish that I'm having done. I'll post pics when it's done.
Old May 7, 2006 | 06:31 AM
bullseye's Avatar
bullseye
The thing with powder-coating, which is an electrostatic application process, is that the finsh is extremely evenly applied to every area of the part. Parts with irregular shapes and/or nooks and crannies, which otherwise would be difficult to spray paint evenly, come out very evenly coated, without using too much finish.
Old May 7, 2006 | 03:13 PM
booger's Avatar
booger
I just painted mine a high gloss black . The original grille color comes thru the black paint to make it look like black chrome
Nismo350z#0310
Wheels Tires
23
Jul 17, 2014 09:20 AM
dcains
Feb 6, 2014 04:40 AM
Dec 23, 2013 09:02 PM
craig12895
Aug 1, 2013 01:01 PM
Guilty1s
Brakes
20
Apr 28, 2011 07:06 PM
