need help!
Old May 10, 2006 | 04:56 PM
Alex000000's Avatar
Alex000000
Default need help!
Hi, everybody please tell me what's kinds of cam is better for 350z. thank you
Old May 10, 2006 | 08:18 PM
fowlman01's Avatar
fowlman01
You need two and make sure they have lots of lobes on them. the lobes make all the difference in the world.
If you try search you might get more ideas.
Old May 10, 2006 | 09:14 PM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
Make sure you get some with a flux capacitor.
Old May 10, 2006 | 09:31 PM
taurran's Avatar
taurran
What I'd recommend is pulling your stock cams and grinding them down. The closer they get to perfect circles, the better.
Old May 10, 2006 | 09:38 PM
cleanandquick06's Avatar
cleanandquick06
i switch mine out of my honda 4 banger accord, shoots my *** down the quater, low 9's
Old May 10, 2006 | 10:54 PM
sja177's Avatar
sja177
hahaha
Old May 10, 2006 | 11:05 PM
Ringo's Avatar
Ringo
Nah, Hraes is right on with the flux capacitor. Do it.
Old May 10, 2006 | 11:17 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
the right size
Old May 10, 2006 | 11:23 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Real men make cams out of crushed up beer cans pieced together with duct tape.
I did this, it was a $6 mod because that's how much my 6 pack cost.
Alternatively you can use the search button
Old May 11, 2006 | 02:46 AM
undrgnd's Avatar
undrgnd
Don't listen to these guys, I took my engine apart for you and found four of them. Just make sure you have 2 on each side and that they are smooth or you can grind them down, and you'll be set.
Old May 11, 2006 | 09:09 AM
VO...'s Avatar
VO...
Administrator
Only Miller lite cans work though.
Old May 11, 2006 | 09:17 AM
fowlman01's Avatar
fowlman01
Doesn't the Z use pushrods.
Old May 11, 2006 | 09:29 AM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
no it uses flux capacitors.
Old May 11, 2006 | 12:18 PM
Wholey Smokes's Avatar
Wholey Smokes
Well, I'm guessing you're new and that French is your first language.
If you have the 300HP motor, cams aren't available yet (at least on the exhaust side).
If you have the 287hp motor, there are plenty of options that seem good. (JWT as mentioned above, for example.)
Old May 11, 2006 | 12:26 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Originally Posted by William@Altered
hey guys - cut the guy a break - he obviously doesn't know much - I would recommend the JimWolf Technology cams - they yield good power and do really well with forced induction
william its called attack and kill newbies with stupid a** questions.killlllllllllllll them all.
Old May 11, 2006 | 12:33 PM
robbycolli's Avatar
robbycolli
Is it true that if you are running test pipes and intake you dont need cam?
Has anyone tried 93 octane cam?
