Worst mod I've ever done... Topspeed/B&M short shifter
Old May 12, 2006 | 05:09 PM
GMZ's Avatar
GMZ
Originally Posted by plumpzz
the stock shifter is great, but if i was interested in getting a shorter shift, i'd get the mossy one. its amazing when i felt it. when i played with it it was on the 33% longer and it was butter smooth.
Hmmm I may be driving by Mossy in the next few days. I remember seeing one in the display when I got my exhaust. Does the Nissan Motorsports shifter affect the warranty at all?
Edit: I also think that the stock shifter is nice if a little tempermental at times, but that adjustable one wowed me!
Old May 12, 2006 | 08:39 PM
wesismyhero's Avatar
wesismyhero
stock plus a nismo shift **** works wonders for me
Old May 12, 2006 | 11:58 PM
plumpzz's Avatar
plumpzz
if your looking for a small shortening, nismo shiftknob will shorten it a little...
the mossy one is a modified OEM one, i cant see why it would void ur warranty on what? If the shifter breaks, they're not gonna replace it. Mossy has a warranty for that. Instal it ur self, its pretty easy. Its the most expensive one, but for a reason.
Old Jun 7, 2006 | 04:19 PM
MyNismoRoadster's Avatar
MyNismoRoadster
Originally Posted by MIAPLAYA
The adjustable shifter is made in Socal so I don't know whats coming from Japan.
What you mean by Socal? Its made by C's for Nissan from what i heard, C's is a Japanese company.
Old Jun 7, 2006 | 04:54 PM
Project Hex's Avatar
Project Hex
I have the rogue engineering and its awesome. No problems at all. And no matter what some people say it def. made a big difference, it feels so much easier to shift now.
Old Jun 7, 2006 | 05:56 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
Originally Posted by gersteinp
Wow--It amazes me how many folks hate the B&M. I figured out the proper way to install it and it's just excellent--short, quick, precise throws and almost totally silent except under hard throttle at certain RPMs--barely audible. It took me about 3-4 weeks to get used to the harder shift effort and now I much prefer it. There's no way I could go back to stock.
There's a trick to installing the B&M shifter to remove any slop or vibration that I explained in another one of my posts a few months ago.
+1 Mine has been quiet and issue free since installing it over a year ago. I couldn't go back to stock now, no way. The B&M is the shortest throw IIRC.
Old Jun 7, 2006 | 10:37 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Originally Posted by Alberto
short shifters suck
My revised 350evo is awesome!
Old Jun 7, 2006 | 10:52 PM
sentry65's Avatar
sentry65
the burninator
+1 aside from the noise.
Shifting is much smoother with ball bearings
if it's good enough for 350EVO to race with, it's good enough for me to drive with
I had the rogue before and started wishing I had the stock one put back in. The 350EVO is better but rattles
Old Jun 7, 2006 | 10:55 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
You have rattles? Mine is smooth as butter
Old Jun 8, 2006 | 09:51 AM
sentry65's Avatar
sentry65
the burninator
well it rattles sometimes but not always - i dunno it's moody i guess. The rattleing stops as soon as you touch the shifter and tug on it just the slightest - like if you're in 2nd gear and you pull it slightly more into 2nd gear if that makes sense - i'm talking barely touching/moving it though
I've had my mechanic mess with it a few times already and it always wants to come back to rattling. He's running out of ideas
what was the trick you used to install it?
it's so much smoother and quicker though I'm never taking it out. Other people who've driven my car have commented it feels really quick like a sequencial or something - not like your normal short shifter
Old Jun 8, 2006 | 10:15 AM
gersteinp's Avatar
gersteinp
You need to wrap the pivot housing in a couple of layers of stretched electrical tape. You don't even have to take the unit out. Just wrap the top 3/4" or so. Then greases on top of the tape and sound proof both boots for even better silence if you want. Be sure that the **** is all the way tight. It's easy to miss the last 360 degree turn. The final turn is fairly tight.
The tape mod gets rid of any remaining slop in the shifter.
Old Jun 8, 2006 | 10:22 AM
sentry65's Avatar
sentry65
the burninator
hey thanks - so you can do that just from sitting in the driver seat and taking off the console housing? I'll have to try that tonight
Old Jun 8, 2006 | 10:30 AM
gersteinp's Avatar
gersteinp
It's easy and quick. Just be sure to clean the grease off of the housing so the tape will stick tight. Once it's taped, the housing should feel pretty snug in the transmission casing but still go up and down without binding. You have to play a little with the amount of tape you use. After I did this simple mod, the B&M was the total bomb!
Old Jun 8, 2006 | 10:43 AM
sentry65's Avatar
sentry65
the burninator
I'm going to try it with my 350EVO shifter and see what happens
Depravity
Oct 1, 2015 04:49 PM
Dymsi
Sep 29, 2015 11:32 AM
Tochigi_236
Sep 27, 2015 03:40 PM
