sun auto hyper force install
Old May 16, 2006 | 07:40 PM
Zincognito's Avatar
Zincognito
what about the better gas mileage that its suppose to give you? very interested in this......
Old May 16, 2006 | 08:47 PM
islandsnow's Avatar
islandsnow
So far i think i'm about the same in mpg, i've been flooring it more since it feels smoother. The engine sounds different too, like it is combusting better, hard to explain, but it just sounds better. I'll know more at the end of the week as far as mpg goes.
Old May 17, 2006 | 12:54 AM
Zincognito's Avatar
Zincognito
when you say it feels smoother across the rev range, what do u mean?
that sounds stupid, sorry i havent driven my Z in almost 3 weeks so i forget what the feel for it is. i need to get home and drive that thing
Old May 17, 2006 | 07:18 AM
islandsnow's Avatar
islandsnow
Well sorry if it sounds stupid, but that's how it feels. It feels more like i just got a good tuneup with the higher spark output i guess, so it revs smoothly all the way to redline. I don't know how to explain it, it just feels and sounds a little different then before in a positive way.
Old May 17, 2006 | 05:01 PM
Zincognito's Avatar
Zincognito
Hey my bad, that sounded completely wrong on my part. I meant that "I" sounded stupid asking. Thanks for the help.
G
Old May 17, 2006 | 05:27 PM
350Zenophile's Avatar
350Zenophile
Do you have any other mods? It's probably just your ecu relearning. I experienced the drop when I put the Popcharger on, but the ecu fixed it after a few drives.
Did you have to remove the strut tower bar and intake tube to install?
Old May 17, 2006 | 06:46 PM
Zincognito's Avatar
Zincognito
I dont think the strut bar or intake tube have to be remove.......sounds like plug and play to me....
Old May 17, 2006 | 09:26 PM
islandsnow's Avatar
islandsnow
No problem Zincognito . It's definitely easier if the intake tube is off, just more room to unclip those harnesses. Plus i wanted to route the wires under the plastic engine cover, so I took off the strut bar too.
Old May 19, 2006 | 10:42 PM
Zincognito's Avatar
Zincognito
makes sense^^
i ordered mine from Rick yesterday so i cant wait till i get mine. i also just received MRev2 so i will probably install them at the same time since the strut bar is gonna be off. ill let you know what i think about the Sun unit.
G
Old May 20, 2006 | 12:23 AM
islandsnow's Avatar
islandsnow
I think you'll like it, it's worth it just having that pulsing blue LED .
Old Jul 12, 2008 | 06:34 PM
JSpec350GT's Avatar
JSpec350GT
Any updates from performances along MPG?
Old Jul 13, 2008 | 04:21 PM
islandsnow's Avatar
islandsnow
If you are expecting gas savings, i wouldn't buy one of these units. I think it would be hard to find someone that just added this hyperforce to a stock car but that would be a good gauge to see if it really helps or not. For my car, i thought it felt smoother. Do i get better gas mileage? I'd say no, but i don't drive it for gas mileage so i'd be the wrong person to ask. If anyone else wants to chime in....
Old Jul 13, 2008 | 05:59 PM
NiZMo1o1's Avatar
NiZMo1o1
so this a basically a amplified box to the coilpacks?
Does anyone have more pictures of this setup out of the box ?
Im checking goggle and all it shows it the blue box, what else is envoled in the install ? I would like to see if I can benifit off this unit for my 04 Maxima.
Also is anyone using this setup with n2o/boost yet ?
Old Jul 14, 2008 | 07:40 PM
NiZMo1o1's Avatar
NiZMo1o1
can someone shoot me more info , is it just a postive negative to the box ? and a plug in to the coil packs ?
Old Jul 15, 2008 | 04:47 AM
350Zenophile
Here's some pics of mine I took installed and out of the box. There is a main power lead that you connect to the battery and then the rest of the wire loom contains jumpers that connect between inline with each individual coil. Small fingers and/or patience helps with the install.
Attached Thumbnails sun auto hyper force install-img_0013.jpg   sun auto hyper force install-img_0007.jpg   sun auto hyper force install-img_0009.jpg
Old Jul 15, 2008 | 08:59 PM
NiZMo1o1's Avatar
NiZMo1o1
Cool thanks for the pics , now I can visual see the harness for the coilpacks..
Going to Nissan to check if the Zs and Maxima are the same.
Would be a nice upgrade
Old Jul 17, 2008 | 05:43 PM
JSpec350GT's Avatar
JSpec350GT
So basically it just it just cleans up and smooth out RPM with a cool LED blinking...wow.
Thanks for your feedback man.
Old May 26, 2009 | 12:49 PM
  #38
Dr. Venture's Avatar
Dr. Venture
Hate to bring this thread back, but i've been reading up on this thing, and i want to know if it is even worth anything major in the long run. Cause what i think is if it was worth it then why didn't the manufacturers already incorporate it from the beginning?
Old Mar 8, 2010 | 04:24 PM
  #39
badnblk's Avatar
badnblk
how about the 6 ground wires where did you guys hook these to i installed my kit but my instructions were japanese so my hyperforce has no light on but the car runs. i ran the grounds to each coil pack but im guessing this is the problem
Old Mar 10, 2010 | 07:33 PM
  #40
islandsnow's Avatar
islandsnow
I think i put all 3 from one side together and grounded them to the nearest ground screw, which there are tons to choose from around the engine. As long as it's grounded i'm sure it's fine.
