Is it normal to smell gass after WOT
Old May 13, 2006 | 10:30 PM
hiimwayne's Avatar
hiimwayne
Newbie
Default Is it normal to smell gass after WOT
I tend to smell fuel everytime i punch the gas.I drive a g35 coupe 5at.I always switch to Neutral when I'm stopped or at a red light. Is that bad for the transmission?. I hate leaving my legs on the brake
Old May 14, 2006 | 01:23 AM
NissanZfan's Avatar
NissanZfan
Okay...I will attempt to answer your post, although I don’t know what one has to do with the other.
1. No it is not normal to smell fuel when you punch the gas. I don’t understand how you can smell fuel when you are going at high speeds. Can you smell it in the cabin, under the hood? More info is needed. Maybe there is a recall on the fuel line, like in my 03 Z? Maybe you have the trunk open and its exhaust?
2. Why would you leave your foot off the break pedal when stopped? I would be worried maybe I will get rear ended and fly into the intersection. Are you really that lazy to not hold the break? It would seem to me it would take more work to switch gears. Although in my 6 speed I put it in neutral when stopped but hold the break. No it is not bad for the transmission, at least not worse than you putting it in drive, park, etc.
Old May 14, 2006 | 01:50 AM
myZter's Avatar
myZter
PREMIER MEM.FTW
you need to press the brakes so the person behing you wont slam in to your @ss
Old May 14, 2006 | 03:35 AM
recklessfour's Avatar
recklessfour
+1
Old May 14, 2006 | 08:38 PM
Redfoot's Avatar
Redfoot
How does pressing the break pedal stop drivers from hitting you in the rear end? please explain.....
Old May 14, 2006 | 09:41 PM
Acree's Avatar
Acree
I believe so the 3rd brake light stays lit. Therefore, people behind you know that you are braking or stopped. I always hold mine down, even if I have the clutch disengaged.
-Acree
Old May 15, 2006 | 04:44 AM
Kolia's Avatar
Kolia
How many miles do you have? it could be as simple as a dirty air filter. 30k miles is the recommanded interval for changing it. Less is it's really dirty outside.
I agree with the idea of holding the brakes to keep the tail lights on.
BUT, since he drives an AT, it's better to let go of the brakes so that the pads don't stick to the rotors. You can get brake shudder because of that. I'd brake, and then move forward a bit to have the rotors turn a bit after stopping. Then hold the brakes.
Old May 15, 2006 | 12:21 PM
DG350Z's Avatar
DG350Z
Many times if you haven't given the car WOT in some time, then gun it, you will smell carbon/gas burning in your engine. This is normal and cleans the excess carbon in your engine. However, if you give it WOT all the time...and the smell is very noticable...then id say no it isn't normal. I take my foot off the brake in nuetral (6mt) at stop lights...
Old May 15, 2006 | 03:35 PM
undrgnd's Avatar
undrgnd
WTF are you talking about? Have you read what you just wrote? Could you find me one article on the whole internet that even remotely supports what you just said?
Old May 15, 2006 | 04:19 PM
Kolia's Avatar
Kolia
With that kind of comment, I'm not sure you're even worth the time to educate you...
Since you seem to be from the internet generation (ever heard of things called books?), I'd suggest you search for a white paper written by Caroll Smith titled The "Warped" Brake Disc and Other Myths of the Braking System.
You can apologies afterward...
Old May 15, 2006 | 04:22 PM
zz350zz's Avatar
zz350zz
The gas you smell is the fumes from the exhaust leaking in through the trunk area. Same principle as a glass hatch that's open on an Explorer or something. When you pin it, the air flow around the car circulates the fumes inside.
Old May 15, 2006 | 05:05 PM
undrgnd's Avatar
undrgnd
I looked it up, found it, read it twice, and understood it. I suggest you go back and read it yourself, and we will forego making a spectacle here. As you will re-discover, you misunderstood completely what Mr. Smith said. He was describing the process whereby coming to a complete stop following high speed braking DURING BREAK-IN is not advisable. This is a well known procedure recommended by most pad manufacturers. NOT during every day driving with an auto. You're welcome.
Old May 15, 2006 | 05:59 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
After 2 hard stops, if I come to a red light and hold the brake pedal down, I will later see an imprint of the pad on the rotors.
Why don't you calm down a little bit and have a beer...
Old May 15, 2006 | 06:02 PM
zz350zz's Avatar
zz350zz
hahaha nice way to put it there Wired. But agreed it is common sense undrgnd. You could replace beer w/ shots of preferred liquour too.
Old May 16, 2006 | 04:21 AM
Kolia's Avatar
Kolia
I'm on coffee myself
Old May 16, 2006 | 01:00 PM
Netko350Z's Avatar
Netko350Z
Do you have a fuel return system?
Old May 28, 2006 | 07:41 PM
Jpc0003's Avatar
Jpc0003
After i punch it i don't smell gas but i do smell something, can't quite put my finger on it though
sales@czp
Sep 23, 2019 03:30 PM
3vilbunny
Jul 18, 2017 05:10 PM
codek
Sep 28, 2015 03:03 AM
