Mileage is suddenly really bad!
Old May 16, 2006 | 03:57 AM
ZinMiami's Avatar
ZinMiami
Default Mileage is suddenly really bad!
Without changing any driving habits my mileage has really gone south! My Z never did any better MPG than 16.3 to 17.2 according to the onboard computer. Suddenly over the course of the last week, it has dropped to 13 to 15 at best.
The last mod was a Borla TD and Kinetix cats. All was well after that install for about a month. Now mileage is suffering. The car is running fine as usual.
Any ideas?
Old May 16, 2006 | 04:21 AM
Evo_Z33's Avatar
Evo_Z33
whoaaaaa..... im not sure what kinda style you are driving, but i get 22-26 mpg base on the onboard computer. I also keep track of it by reseting the milage screen everytime i put in gas and its fairly accurate.
Old May 16, 2006 | 04:24 AM
nothingremains's Avatar
nothingremains
hmmmm that is odd, my car has 100 miles on it and im averaging 21 mpg
Old May 16, 2006 | 06:12 AM
abstrakt's Avatar
abstrakt
Is your gas guage reading properly? Fill it up at the pump and see if the needle is going all the way to F. If not, then take it to Nissan and have them look at it. It could be that your sensor has gone bad.
http://www.nissanhelp.com/Bulletins/350Z/Year.htm
Old May 16, 2006 | 01:43 PM
ZinMiami's Avatar
ZinMiami
I think the computer or sensor it reads may be bad. I watched carefully today and mileage stays relatively constant while cruising but at a stop it is dropping .5 MPG every 30 seconds or so. I know that idling is wastefull, but it never dropped that fast before. In the span of sitting at 1 red light I went down about 2 mpg! Its never gone down that fast at idle in the past.
Old May 16, 2006 | 01:45 PM
chimmike's Avatar
chimmike
its hot out now too, remember
Old May 16, 2006 | 02:00 PM
Cannysage's Avatar
Cannysage
Yo,
that's actually normal. Your computer is adjusting to your new mods. Mine averages 17.5 and it went up to 28mpg then down to 14. It went back to normal after about 400 miles of driving - this was after exhaust and testpipe, as well. did the same thing with the popcharger, although not as severe.
Old May 16, 2006 | 02:11 PM
z350boy's Avatar
z350boy
Any ideas?
Your'e better than me. Since I got the car in Sept '05 I HAVE NOT GOTTEN BETTER THAN 15MPG!!!!!
Old May 16, 2006 | 02:22 PM
tcn75's Avatar
tcn75
Next time, remember how many gallon you put in the tank, and how many miles does the Z take to empty. The do the math yourself, 400miles/20 gallons = 20mpg. my Z usually run 400 miles/18 gallons = 22.2mpg (if you dont trust gas guage reading)
Old May 17, 2006 | 02:42 AM
abstrakt's Avatar
abstrakt
+1...I don't think the guage in the center concole pod is very accurate...it's more for show. You have to constantly reset it so that it takes into acct your average speed. The best way to calculate your MPG is the way tcn stated above. Run the car till your close to E, fill up tank and keep receipt so you know how many gallons it took. Reset trip readout on the odometer and then when you get down close to E. Take the total trip miles and divide by the gallons pumped
Old May 17, 2006 | 10:59 AM
ht4's Avatar
ht4
Release your e-brake.
Old May 17, 2006 | 11:01 AM
sq40's Avatar
sq40
Fuel line leak?
Old May 17, 2006 | 11:40 AM
xziteme's Avatar
xziteme
I was getting 12mpg when I was doing the 1000 mile oil consumption test (per dealer for excessive oil consumption). It turned out I was burning excessive oil and the dealer changed my short block, under warranty.
Check your oil level too.
Old May 17, 2006 | 11:56 AM
suprpwr's Avatar
suprpwr
after installing my Stillen exhaust (along with a Pop) my gas mileage seems to have gone down as well. could the issues be at all related to the A/F ratio? I've been considering getting my ECU reflashed to possibly help the situation (which I've been told doing so might)
Old May 17, 2006 | 12:03 PM
bimma78's Avatar
bimma78
Could be that they are putting Ethanol(sp ?) in the gas now
Old May 17, 2006 | 12:20 PM
ngcharleshk's Avatar
ngcharleshk
I have the same problem on my Z after installing the popcharger. However, the gauge is absolutely not accurate in the first place, it fluctuates up and down like a champ the whole time in local driving. Dont trust the gauge, you should just calculate how many miles you have driven before the yellow light goes on to estimate MPG.
Old May 17, 2006 | 01:29 PM
overZealous1's Avatar
overZealous1
the mileage computer keeps calculating even while you are standing still. so your mileage gauge will say you are getting horrible gas mileage, while you actually are not. it is a design flaw in my opinion. it should only calculate while the car is moving. it is even worse if you have reset it recently, as it will not have many miles to base the average off of and standing still will drop it quickly.
Old May 17, 2006 | 01:42 PM
Fuel mileage does not suddenly change.
Going from winter to summer mileage may decrease 1 mile/gallon. The problem is accurate measurement of mileage from one tank to another. If you calculate 17 mpg for one tank then 15 mpg for the next means little: just that your driving pattern is different.
Old May 17, 2006 | 04:25 PM
undrgnd's Avatar
undrgnd
so many experts, so little truth...
Old May 18, 2006 | 08:58 AM
overZealous1
my idea is right though, lol. test it. reset your mileage comp while on the freeway for about a half hour, to get a really high mileage count, then go home and let the car idle in the driveway. your mileage will drop huge amounts, even though the car is not even moving.
