Neuterting VDC, TCS, ABS, and ABLS??
Old May 16, 2006 | 05:51 AM
moorefire's Avatar
moorefire
Default Neuterting VDC, TCS, ABS, and ABLS??
Howdy, I'm Will. I'm a new 04 g35 6mt owner and I was wondering if anyone has come up with a clean solution for disabling all the e-crutches on the v35/z33. I'd like to be able to daily my car with everything off but be able to switch them back on for torrential rain and snow.
So if I'm understanding this right, if I cut power to the Yaw and VDC modules, I'll lose the VDC and TCS with no bad effects besides the SLIP and VDC off lights? Will doing this disable the Active Brake Limited Slip also?
Is there any way to also disable the ABS withough losing brake lights or messing with the speedo?
anyone else try to tackle this yet? I seached and got this far but I'm still clutchin at straws...
thanks in advance
PS: it is of my opinion that ABS is for commuters and the VDC, TCS, and ABLS is an engineering band aid to make up for using a POS VLSD rear end, so thats why I wanna do this.
Old May 16, 2006 | 08:12 AM
seanlaw's Avatar
seanlaw
to remove the ABS you'll have to remove the actuator for the brake fluid distribution and run just straight brake lines. probably also just take the fuse out for the ABS.
as for the VDC stuff there are threads about it...search disabling VDC
Old May 17, 2006 | 12:54 AM
punish_her's Avatar
punish_her
I'm still looking for a way to disable the power cut safety feature for braking and throttle. More specificly for the Enthusiast. I know the Yaw power mod will do this but ET's lack the Yaw sensor to mod so what now. No one has given a half a$$ed straight answer except search, which I've done and read every page. The mods mentioned there in are all yaw sensor specific nothing for ET.
loudtoyz
Apr 6, 2023 04:52 AM
AbrasiveRaysive
Sep 20, 2021 02:29 PM
350Z_Al
Oct 29, 2020 07:44 PM
