What gear to dyno in?
Old Feb 11, 2003 | 05:18 PM
CottonWoodz's Avatar
CottonWoodz
Default What gear to dyno in?
What gear, should a 6sp be dynoed in ?? And why. Thanks
Old Feb 11, 2003 | 05:23 PM
2003z's Avatar
2003z
OUR 6 speed should be dyno'd in 5th gear, as that is a 1:1 gear ratio. Can't speak for other 6 speeds.
Old Feb 11, 2003 | 05:53 PM
ares's Avatar
ares
Veteran
the 1:1 gear or 5th as was said.
but some places dont want to dyno in 5th since at redline your tires are rolling at like 140mph... the difference between gears is quite minimal. as long as you always dyno in the same gear, its ok.
Old Feb 12, 2003 | 08:43 PM
KJ-350's Avatar
KJ-350
as everyone else said, the "proper" gear would be 5th. that is where you would get the most accurate numbers. but then again around here the dynos suck and read either to low or to high.
one thing I've come to realize about the dyno is just to be worried about consistency! as long as you keep your runs the same each and every time you make a mod you will have as close to accurate gains or losses to show! the end numbers might not be as high or low as your looking for but showing the differences will always be there and that is key!! if you run the 1st time in 4th for baselines stay with that EVERY time after! and same with 5th! if you keep changing up your numbers wont be as true as they should! $0.02
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
NissanZcrazy
Sep 23, 2015 07:59 AM
Bodyboarder81
Sep 21, 2015 06:23 AM
