Stock injectors HP capacity
Old May 21, 2006 | 02:04 PM
wren57's Avatar
wren57
Default Stock injectors HP capacity
Just wondering how much HP the stock 280cc injectors can handle. I did some datalogging with my UTEC and it looks like my stockers are working pretty hard...
Old May 21, 2006 | 03:16 PM
plumpzz's Avatar
plumpzz
about 300whp or so. Its possible to run out of fuel on stock injectors NA i believe, especially with tuning
Old May 21, 2006 | 04:10 PM
Z350Lover's Avatar
Z350Lover
yeah.... I maxed out my stock injectors with all my n/a mods, so I got mine modified and they work great!
cheers,
richie
Old May 21, 2006 | 04:24 PM
wren57's Avatar
wren57
Ugh, not good... I'm guessing that when I get my headers installed and get a good UTEC tune I'll be close to 300whp... might need to add injectors to the list.
Old May 21, 2006 | 04:55 PM
plumpzz's Avatar
plumpzz
you can get the stock ones modified for cheap, or get deuschtech (whoa spelling). They're cheap modified stock.
Old May 21, 2006 | 06:28 PM
Z350Lover's Avatar
Z350Lover
I didn't run out of my stock injectors until I rebuilt my engine the 2nd time... with nismo s1 cams, the stock injectors were still alright, there is no need to waste your money doing that (you will just waste your fuel and money)... I only maxed out the injectors with the new pistons, new valve trains and rods... so with those bolt-on mods (exhausts or plenums), you will not need to touch the injectors though...
EDIT:
I only ran out of injectors at higher rpm range... from 7500rpm to 8000rpm... and below 7500rpm, there was no problem...
cheers,
richie
EnjukuRacing
Sep 30, 2015 06:55 AM
