For those with a radiator breather tank
Old Jun 3, 2006 | 04:37 AM
aalzuhair's Avatar
aalzuhair
Question For those with a radiator breather tank
Could you please show us where did you install the breather tank and the hose routing?
Thanks,
Az
Old Jun 3, 2006 | 07:43 AM
Gman2004's Avatar
Gman2004
here ya go.
Attached Thumbnails For those with a radiator breather tank-ride-with-a-g-007.jpg
Old Jun 3, 2006 | 08:29 AM
350zbiturbo's Avatar
350zbiturbo
What is a radiator breather tank? What does it do?
Old Jun 3, 2006 | 09:35 PM
aalzuhair's Avatar
aalzuhair
Originally Posted by Gman2004
here ya go.
Thanks. Could you please explain the routing of the hoses. I can see that you have a one way valve between the breather tank and the overflow tank, why?
Also you have two other hoses, one is connected to the neck of the radiator. and the other one is connected to ????
Thanks,
Az
Old Jun 3, 2006 | 09:38 PM
aalzuhair's Avatar
aalzuhair
As explained by GReddy: "Designed originally for racing engines, today’s compact production engines can also benefit from the used of GReddy’s Radiator Bleed Tank. By mounting the tank high up in the engine compartment, you can be assured that of a fully filled system with room for air expansion, thus reducing chances of overheating due to air-lock."
Old Jun 3, 2006 | 09:40 PM
aalzuhair's Avatar
aalzuhair
It's the circled object
Old Jun 4, 2006 | 03:42 PM
Gman2004's Avatar
Gman2004
Thanks,
Az
SGP did the install for me so I don't know why the hoses go where they go. The other clear hose go directly under the throttle body and t's in some line that is located there.
Old Jun 5, 2006 | 06:34 AM
350zbiturbo
So does this breather tank help with keeping air from getting into the system?? I think thats one of the problems I have, that Im always getting air bubbles in the system.
Old Jun 5, 2006 | 07:39 AM
Gman2004's Avatar
Gman2004
It doesn't help keeping air from getting into the system, but it gets it out.
Old Jun 5, 2006 | 08:10 AM
gringott's Avatar
gringott
I have this tank also and am wondering. I know (or think I do) that
1 Hose on the bottom goes to the lower radiator hose.
1 Hose on the top goes to the radiator neck.
1 Hose on the top goes to the expansion tank.
Here is where I am not sure
1 Hose on the top goes to ???
Maybe the heater hose with the plug that you are supposed to open when getting the air out of the system??
By the way, I have a Maxima service bulletin that my friend gave me that basically has you make a tank something like this for the service people to get the air out. But it is not as comprehensive as this bubbler tank.
Old Jun 5, 2006 | 08:33 AM
aalzuhair's Avatar
aalzuhair
Yeah it could be that way .... its starting to make sense .... if any air bubble is coming out of the engine or the heater hose it will go to the breather tank an then to the overflow tank
Old Jun 5, 2006 | 09:19 AM
350zbiturbo
well anything that could possibly help with cooling my car down I think im gonna get? Do you have to have the greddy kit to get this tank? If not where can I get this from????
Old Jun 5, 2006 | 09:29 AM
gringott's Avatar
gringott
Got mine on ebay from this guy:
You are the winning buyer for the item below. Thank you for your business!
Item title: NISSAN HONDA MAZDA TOYOTA RADIATOR BREATHER TANK
Web address: http://stores.ebay.com/maxspeed-motorsports
Seller User ID: maxspeed-motorsports
Your total is:
$60.00 per item
$1.20 insurance (optional)
$0.00 Sales discounts (-) or charges (+)
$14.95 shipping/handling
$74.95 = Total
Old Jun 5, 2006 | 10:21 AM
captj3's Avatar
captj3
How much boost are you running? You may have some headlifting going on there. You may also want to think about SVRs studs to help keep the heads in place.
Old Jun 5, 2006 | 11:06 AM
dolemizer's Avatar
dolemizer
They help remove air from the cooling system. I'm not sure how effective or necessary they are on the Z, but they do work. My buddy has an rx7 and they have breather tanks from the factory.
Lots of atermarket breather tanks out there. Most have a similar design
Old Jun 5, 2006 | 03:35 PM
350zbiturbo
I dont want to high jack this thread but How am I supposed to tell if the heads are lifting??? Im running like only 9 pounds right on a built motor b/c I cant find anyone to tune it, and I cant tune it till I fix the overheating problem anyways.
Old Jun 5, 2006 | 04:06 PM
Gman2004's Avatar
Gman2004
at 9psi I don't think it's your heads are lifting. There's either serious air in your system or your radiator is fuked. When I had my stock radiator it was leaking from the seems, but only under boost so I didn't know it was leaking. Maybe your are having the same problems?? Do you have to refill your system often?
I know this isn't what you want to hear, but with all the money you have invested already, I would buy an aftermarket radiator, the breather tank, and SRVT head bolt mod. If you buy all those mods you should be able to retune and boost it up to 16psi or so with no problems. Hit me up and we can meet up some time.
Old Jun 5, 2006 | 08:50 PM
dscheers's Avatar
dscheers
Does this pic help anything ?
Old Jun 6, 2006 | 06:19 AM
350zbiturbo
Well I cant buy a radiator until I found one that fits. The turbonetics kit has a pipe that runs in front of the motor and I cant fit fans with the bigger koyo radiator.I have to first find a radiator that fits. So I guess Ill buy the breather tank and the SVRT Bolts first until theirs a way to fit a radiator.
Old Aug 18, 2006 | 09:25 AM
Quamen's Avatar
Quamen
Question,
Where is the bottom hose tot he breather tank connected into the cooling system at?
Also, do you still retain the factory radiator cap or do you actually take the spring out so that it is free flowing into the breather tank at all times?
