3.9 final drive top speed
Old Jun 8, 2006 | 12:11 PM
cleanandquick06's Avatar
cleanandquick06
Default 3.9 final drive top speed
someone with 3.9 fd, please tell me what you now top out at? im guessing in the 145mphish range? dont flame me, its just a guess, thats why im asking. i searched and didnt come up with shiit
Old Jun 8, 2006 | 12:47 PM
sentry65's Avatar
sentry65
the burninator
it's 158-166 depending on your tire diameter - assuming this is for a manual Z. The normal theoretical top speed in a stock manual 350Z is 184mph if the ECU would let you rev 6th gear all the way out
http://www.f-body.org/gears/
Old Jun 8, 2006 | 01:20 PM
Oleg's Avatar
Oleg
Find out how many % shorter your final drive is going to be and that's how many % you are losing off of each gear.
How's that exhaust anyway?
Old Jun 8, 2006 | 01:24 PM
sentry65's Avatar
sentry65
the burninator
yeah but it doesn't work that way for 6th gear because the stock top speed is way higher than the ECU will let you with the 160mph limiter
Old Jun 8, 2006 | 01:39 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
i worked out the math in a thread...
I did this for the AT guys....
Ok here are my calculations on the gears:
1st - 3.540
2nd - 2.264
3rd - 1.471
4th - 1.000
5th - 0.834
Stock Tire Size 245/45/18 = Revs Per Mile = 756
FD = 3.3
FD = 3.538
FD = 3.700
FD = 3.917
Formula:
RPM / FD Gear Size / Tire RPM x 60 = Speed in MPH
RPM:
3000 RPM in 4th Gear:
3.3 @ 3000 RPM = 72.15 MPH
3.538 @ 3000 RPM = 67.29 MPH
3.700 @ 3000 RPM = 64.35 MPH
3.917 @ 3000 RPM = 60.78 MPH
3.3 @ 6000 RPM = 144.30 MPH
3.538 @ 6000 RPM = 134.59 MPH
3.700 @ 6000 RPM = 128.70 MPH
3.917 @ 6000 RPM = 121.57 MPH
Forumla for other gears:
RPM / (FD Gear Size x Tranny Gear Size) / Tire RPM x 60 = Speed in MPH
3000 RPM in 5th Gear:
3.3 @ 3000 RPM = 86.51 MPH
3.538 @ 3000 RPM = 80.71 MPH
3.700 @ 3000 RPM = 77.17 MPH
3.917 @ 3000 RPM = 72.90 MPH
3.3 @ 6000 RPM = 173.02 MPH
3.538 @ 6000 RPM = 161.42 MPH
3.700 @ 6000 RPM = 154.35 MPH
3.917 @ 6000 RPM = 144.21 MPH
6200 RPM in 1st Gear:
3.3 @ 6200 RPM = 42.12 MPH
3.538 @ 6200 RPM = 39.30 MPH
3.700 @ 6200 RPM = 37.56 MPH
3.917 @ 6200 RPM = 35.48 MPH
The 3.7 gear set works with any rear end that will work with the 3.5 or 3.9 gear set...
So, basicly all you need is a 3.5 6MT pumpkin w/ VLSD or can be used with any Aftermarket LSD that works with the 3.5 gear set...
THe 3.70 gear set is: $480 for the gear set alone... You will also need the same pinion nut, pinion seal, spacer housing, bearing, etc etc just like with the 3.5 gear set...
to date ive done half a dozen of the 3.7 gear sets into auto's...
Old Jun 8, 2006 | 02:16 PM
sentry65's Avatar
sentry65
the burninator
yeah I agree with jason's data
I still say this website is your friend
Old Jun 8, 2006 | 09:08 PM
cleanandquick06
so if i did a 3.9 i owuldnt even notice a difference in the top speed cause of the limiter anyways? i would just be at a high rpm when it hit?
Old Jun 8, 2006 | 09:14 PM
cleanandquick06
Old Jun 8, 2006 | 09:32 PM
sentry65's Avatar
sentry65
the burninator
exactly and in fact in some ways that would be safer on the engine cause you'll reach 160mph way sooner than before which means the engine won't have to work as long and hard to get you to 160, though the car would reach 160 just under redline instead of 5600
Old Jun 8, 2006 | 09:36 PM
cleanandquick06
that will be awesome since i have the rev up anyways, thanx guys
Old Jun 8, 2006 | 09:38 PM
sentry65's Avatar
sentry65
the burninator
if you have the rev up engine with the 3.9 FD, your top speed will be close to 175mph give or take depending on your tire diameter
the normal top speed with 3.5 final drive is more like 195 give or take. It's 198mph with the stock tire sizes
it doesn't matter though cause the car probably doesn't even have enough power on it's own to even get to 175 unless you have a lot more power than stock
Old Jun 8, 2006 | 10:50 PM
99atlantic's Avatar
99atlantic
I think you're going to end up being disappointed w/ 3.9s......4.10s were just 'meh' in my books; next time I do gearing it's atleast 4.56s
Old Jun 8, 2006 | 11:43 PM
bhk1004's Avatar
bhk1004
seeing as how quickly we already finish out first, and modded how quickly second is gone, I honestly doubt first or second will ever be useable street gears if u go abover 3.9, unless ur able to rev to 8k or more.
Old Jun 9, 2006 | 07:29 AM
sentry65's Avatar
sentry65
the burninator
who makes a 4.1 FD for our diff?
Old Jun 9, 2006 | 05:29 PM
Oleg's Avatar
Oleg
How do you think the 6MT final drive would affect a TN ST?
First gear is a waste either way, and having to keep higher revs would actually keep the turbo spooled even during cruising, no?
Old Jun 9, 2006 | 06:38 PM
sentry65's Avatar
sentry65
the burninator
you don't really drive at higher revs if you don't want to except for 6th gear
around town, if you start feeling like the rpms are too high, you upshift the same as you normally would. It'd get you into the higher rpms faster. You're going to want a killer tire setup though - like drag radials or competition tires to maintain traction when the TN kit hits peak tq etc
I know one guy that loves it, but most hate the 3.9 with their turbo kit
Old Jun 9, 2006 | 09:02 PM
ReavTek's Avatar
ReavTek
A 6MT is a 3.5? I want to eventually hit 180mph, should I just move up to a 3.7 instead of a 3.9? Who makes a 3.7?
Old Jun 9, 2006 | 09:56 PM
Jason@Performance
Performance Nissan
we have a factory nissan 3.7 final drive gear avaialble...
Old Jun 9, 2006 | 10:00 PM
cleanandquick06
how much is the 3.7
Old Jun 10, 2006 | 06:00 AM
Jason@Performance
Performance Nissan
its around $570 for the gear, pinion bearings, pinion nut, spacer housing...
but i have to check for sure...
Obadabot
Jun 18, 2023 11:31 PM
350Z_Al
Oct 29, 2020 07:44 PM
3vilbunny
Jul 18, 2017 05:10 PM
Depravity
Oct 1, 2015 04:49 PM
