Underdrive Pulleys?
Old Jun 14, 2006 | 11:58 AM
shanecrosby's Avatar
shanecrosby
Got my car back with the full Ultra SS pulley set installed. I can feel a difference. I had my timing advanced 2 degrees down low. The throttle response is quicker and definately noticeable. Sammy is a cool cat..
Old Jun 14, 2006 | 10:04 PM
Zmazing03's Avatar
Zmazing03
I was browsing the internet and saw the UR Pulley Kit. I won't by the HP increase it claims, but I will believe the smoother/faster throttle response. And so, I believe I may add this to the list of "to be done".
Therefore, how hard are they to install. I'd imagine the hardest part would be dealing with the belts.
Old Jun 14, 2006 | 10:16 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
subscribing
Old Jun 22, 2006 | 07:04 AM
sciulli350z's Avatar
sciulli350z
has anyone installed one of these pulleys on there owne, and if so what did you do to get the bolt off of the old crank pulley
Old Jun 22, 2006 | 07:25 AM
Miraclekidjr's Avatar
Miraclekidjr
Yea, all you do is use a breaker bar with a fat man on the end of it. It's pretty easy after that
Old Jun 22, 2006 | 08:43 AM
zachcrosen's Avatar
zachcrosen
Here is the deal...
The crank pulley is the one that provides most of the gains. The other 2 accessory ones are basically for looks. To break this info down even further, approx. 80% of the gains from a pulley are due to the lighter weight of it; i.e. less rotational mass. The stock pulley weighs around 5 pounds give or take and my CNR lightweight(not underdrive) pulley weighs around 2-3 pounds. The other 20% is from the actual underdriving of it.
And you DO NOT want to run a underdrive pulley with a SC as it will lower the amount of boost you see. Logically, if you are underdriving the accessories, then you will be underdriving the supercharger as well!
I do not have actual proof of all of this as I have followed everyone elses advice on here, but it is all info I have gained over the past 2.5 years I have been on this site.
Old Jun 23, 2006 | 08:47 AM
sciulli350z
Is it normal for the crank bolt to be so tight
Old Jun 23, 2006 | 10:47 AM
Miraclekidjr
Yes. It should be nearly impossible to remove, but don't give up.
Old Jun 25, 2006 | 12:57 PM
JDMZ-33's Avatar
JDMZ-33
Guys,
Just wondering does anyone remember the sized of the belts?I'm going to fit the UR light pulley and getting trouble to know the sized of the belts
cheers,
Jerry
Old Jun 27, 2006 | 01:22 AM
Zincognito's Avatar
Zincognito
I believe when you buy the UR crank pulley from Z1 it comes with a belt. i may be wrong...
Old Jun 27, 2006 | 07:11 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
yep - we include the belts
http://www.z1auto.com/prodmore.asp?m...ine&prodid=718
Fixxxercask
Nov 9, 2015 11:10 AM
NissanZcrazy
Sep 23, 2015 07:59 AM
Calinismo350z
Sep 14, 2015 04:04 PM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
