Changing Differential Fluild - additive
Old Jun 13, 2006 | 09:40 AM
350ZREDLINE's Avatar
350ZREDLINE
Default Changing Differential Fluild - additive
I will be changing my differential fluid soon. Going to use Mobil 1 75-90
is there a special additive i need to add as well?
Thanks
Old Jun 13, 2006 | 10:09 AM
No. Use differential oil stated in the manual.
Old Jun 13, 2006 | 01:17 PM
350Zteve's Avatar
350Zteve
Thanks
You generally only need additives (friction modifiers) on clutch type LSD's. The stock viscous diff does not require anything beyond the correct oil. Having said that, get some Royal Purple, Redline, Mobil 1 or Amsoil and you're good to go.
Old Jun 13, 2006 | 01:38 PM
350ZREDLINE
thanks a ton
Old Jun 13, 2006 | 08:32 PM
islandsnow's Avatar
islandsnow
i'm using mobil 1 in with my cusco and no problems/noise
Old Jun 23, 2006 | 09:31 PM
sq40's Avatar
sq40
How much fluid is needed to change for a 6MT Non-LSD.
What type should I get specifically?
Thanks!!
Old Jun 24, 2006 | 12:28 AM
Chebosto's Avatar
Chebosto
drain, and then pump/fill until it leaks.. thats usually what it is.
with my cusco RS lsd, i use a little less than two of the small bottles of mobil1 75w-90.. which i think is less than two quarts
ablaine
Nov 29, 2016 10:13 AM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
