Stillen Oil Pan Spacer
Old Jun 13, 2006 | 05:08 PM
westover's Avatar
westover
Unhappy Stillen Oil Pan Spacer
I think I have messed up. I installed a Stillen oil pan spacer to add a quart of oil to the oil pan. When I tightened up the longer oil pan bolts I think I over tightened the bolts and stripped the engine block threads.
Can this situation be saved? All suggestions welcome.
Thanks
Old Jun 13, 2006 | 06:21 PM
rotaryrocket7's Avatar
rotaryrocket7
You'll need to re-tap the threads. With an aluminum block you cannot afford another oops, if you're up for it go ahead. Otherwise I would bring it to a pro.
Old Jun 13, 2006 | 07:08 PM
Alberto's Avatar
Alberto
Cranky FI Owner
TQ wrench owns you. In all seriousness retap and be careful use proper TQ specs this time!
Old Jun 14, 2006 | 04:27 AM
bobd's Avatar
bobd
If the threads are in fact stripped, you will probably have to install Helicoils.
Old Jun 14, 2006 | 09:34 AM
THE TECH's Avatar
THE TECH
Well if you only did it on one screw, then you'll be fine. If you screwed them all up, then you will need to retap at a minimum.
burglapfd
Dec 6, 2020 01:04 PM
kyin
Oct 15, 2015 05:54 AM
