VQ35 and "other" engine
Old Jun 18, 2006 | 01:03 PM
Ryan Davis's Avatar
Ryan Davis
Default VQ35 and "other" engine
So I heard that there are actualy 2 model engines in the 350Z. I told a friend that now and days you can get a good stock Z for around $18000 to $20000 and he said that thats the one with the bad engine and all the tests that were done like in import tuner etc. it's been on the VQ35 engine and the lowest costing Z, I forgot the model name, is the one with the bad engine and the only ones that have the VQ35 are the higher priced ones. Can someone please explain this to me. Thank you.
Old Jun 18, 2006 | 01:23 PM
John@Victory's Avatar
John@Victory
easiest way to expain it is your friend is a moron that you should never seek car advice from again
Old Jun 18, 2006 | 01:27 PM
GMZ's Avatar
GMZ
Um yea your friend knows nothing. Try a search for "Rev up motor" so YOU can educate HIM.
Old Jun 18, 2006 | 01:57 PM
Mike Wazowski's Avatar
Mike Wazowski
You have been a member for over 2 years and yet you are going to listen to some idiot that knows ****?
Old Jun 18, 2006 | 04:43 PM
Fairlady_z33's Avatar
Fairlady_z33
sorry to say it like the last 3 post ill be the 4th to say it your friend has LD.
He sure doesnt know nothing about cars yea in a way you can say they r two different motors but they r not same platform only one has different heads but its still a VQ35. So that makes it the same motor different head set up.
Old Jun 19, 2006 | 01:53 PM
Kiamo's Avatar
Kiamo
2003 and 2004 Zs all have the same motor (286 HP/274 lb/ft, 6750 RPM redline, variable intake cam timing only). In addition, 2005 Base, Enthusiast, Performance, 35th Anniversary autos, and 2006 autos have this motor. 2005 Track, 2005 35th Anniversary and all 2006 manual models have a revised engine (still a "VQ35DE" model 3.5L V6), but with 300 HP/260 lb/ft, 7000 RPM redline, variable intake and exhaust cam timing.
Both motors perform measurably almost identical. The "older" motor having a slightly stronger midrange and the revised motor having a slightly better topend.
For what its worth in the sake of the original post, all 350Zs have pretty much the same engine. Any 350Z you will buy came from the factory with a 3.5L naturally aspirated 24V DOHC V6.
Old Jun 24, 2006 | 08:33 AM
Ryan Davis's Avatar
Ryan Davis
Hey thanks, that's good to know. He said that all the tests on things like the Greddy turbo kit, etc. was done on the "top end" engines of the Z. Would the Turbo or products that are out fit on the older base platforms in this case. Yea, i've been a member on and off for about 2 years now and i'm currently in training for the Nevada Army Nationla Guard so a lot of us talk cars and I would like to maybe get an older Z if I can for when I get back so i'm double checking on everything before I jump in to finaly getting one. You've all been a great help.
Old Jun 24, 2006 | 08:58 AM
Gumpdriver's Avatar
Gumpdriver
OMG you should slap you friend and tell him to KILL YOUR SELF.
Old Jun 27, 2006 | 06:53 PM
Nismo 350z's Avatar
Nismo 350z
I don't know of anyone putting a Greddy kit on a Rev-up yet but you can turbo the rev-up. Example look at Nitrouz. Almost 90% of FI owners don't own a rev-up, so yes can turbo a base model. The only thing thats not available for rev-ups are cams but I am sure they are coming soon. BTW your friend is a moron and should stick to reading Import Tuner for all his car info.
Old Jun 27, 2006 | 07:04 PM
playa6tnine's Avatar
playa6tnine
your friend is not a true friend my friend.
liqalu04
Jan 2, 2022 12:58 PM
sales@czp
Sep 23, 2019 03:30 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
