HKS Twin Power Ignition Amplifier
Old Feb 19, 2003 | 09:30 PM
Intrepid's Avatar
Intrepid
Default HKS Twin Power Ignition Amplifier
Comments?
http://www.ultimatez.com/shop/index....185&cart=48123
http://www.hksusa.com/categories/?id=1066
HKS twin power ignition amplifier
The Twin Power Ignition Amplifier is engineered to produce a hotter and more efficient spark needed for high performance ignition applications. The Twin Power continuously monitors the coil to allow the ignition system to reach maximum capacity without overcharging. The Twin Power also provides optimum spark duration and voltage output. The Twin Power combines a Capacitor Discharge Ignition (CDI) and a Transistor Ignition into one package. The CDI is used to produce high voltage. The Transistor Ignition controls current to the coil via an impedance matching circuit, producing a longer spark duration. This powerful combination enhances engine chamber combustion for greater horsepower at higher RPM levels and increased throttle response at lower RPM levels. The HKS Twin Power is the most comprehensive ignition amplifier available! Three models Available for distributor, distributor less and rotary type ignitions.
Price: US$478.99
sales@czp
Sep 23, 2019 03:30 PM
