Tranny & diff fluid swap: did I do something wrong???
Old Jul 5, 2006 | 05:55 PM
MustGoFastR's Avatar
MustGoFastR
Default Tranny & diff fluid swap: did I do something wrong???
So the service manual says tranny holds 3.25 qt and diff holds 1.25 qt. I buy 5 qt Royal Purple Max Gear 75W90. I should have ended up with half a quart left over, but had to go buy a 6th quart to top off the diff after doing the trans first??? Looks like the trans held about 3 1/3 qt (just a little over manual specs) and the diff held a little under 1 3/4 qt (a good half quart more than the manual says). What up with that? Car is an '03 Track 6MT and was raised level on 4 jack stands. I drained fluid, then refilled until fluid started coming out of the fill hole and let that drip until it stopped.
Old Jul 5, 2006 | 05:58 PM
outyZ's Avatar
outyZ
Default i can't speak on the tranny
but that is almost exactly what i put in my differential when i changed the fluid
Old Jul 5, 2006 | 07:59 PM
g356gear's Avatar
g356gear
Some diffs and trannys come low on fluid from the factory...it's a big problem with Titan rear diffs.
MustGoFastR
Ok, cool. I'm prob good; just wierded me out a little (and ticked me off that I had to go back to the store to buy more RP) that it took more than the manual stated...
Old Jul 5, 2006 | 08:01 PM
MustGoFastR
Well, I didn't measure how much came out; just looking at how much it took to fill compared to what the manual says it should have taken. Hoping I didn't overfill the diff, but I followed the directions...
Looking over the manual again, the capacity does state that it's an approx. amount and states 1.25-1.5 qt (1.4L or 3pt), so I guess I'm not that far outside what it says.
Word of advice if you're swapping tranny and diff fluids: buy 6qt; 5 may not get the job done. Then again, it didn't take mush at all of that 6th quart to top off the diff, so I probably would have been fine had I just left it, but I couldn't tell how far from full it was so went ahead and topped it off to be safe.
Old Jul 6, 2006 | 06:09 AM
002-M-P's Avatar
002-M-P
I just changed my rear diff. yesterday, so it was pretty much bone dry and it took a little more than 1.5 qt. I have about .4qt left in the bottle and only a little dripped out. Gotta change it again today (break-in), so i will let you know how much it took today.
Old Jul 6, 2006 | 06:24 AM
sq40's Avatar
sq40
My Open Rear Diff took about 1.8 qts to fill.
Old Jul 6, 2006 | 01:20 PM
Gary King's Avatar
Gary King
Your fine as long as it was filled to where it spilled out the fill hole. Enjoy your Royal Purple, good stuff, I highly recommend it and use it exclusively in our Z.
Obadabot
Jun 18, 2023 11:31 PM
lapham3
Oct 7, 2022 03:15 PM
burglapfd
Dec 6, 2020 01:04 PM
