should i pay to get kjr pulley installed
Old Jul 7, 2006 | 11:59 AM
MrKaira's Avatar
MrKaira
Really MrZ31
Originally Posted by DavesZ#3
That's pretty much the way it is with ALL aftermarket parts. The only warranty you get is on the part itself. You assume all risk and liability when you do it yourself. Read through the Forced Induction forum if you want to see some sad tales of blown engines and big $$$$ thrown down the drain.
oh see i thought that as long as you had proof that it was their part that screwed up then it would be covered, in most cases anyway. But since you bring up the FI situations it makes more sense.
Old Jul 7, 2006 | 12:57 PM
03performz's Avatar
03performz
Originally Posted by mrpratt
yes, the pulley was installed to the specifications in the instructions, which was about 30 lb ft not enough, and over time the pulley spun unevenly, eventually sheering off a piece of aluminum from the back of the pulley, onto/into the timing chain, causing the engine to jump time and bend the valves. i have the $4000 bill to prove it too.
Sounds like the blame is partly KJR's fault and partly your mechanics.
The instructions of 30lb/ft. is ridiculous. It's 36lb/ft. + 60 degrees..it's the same as the stock pulley torque specs in the shop manual. Any GOOD mechanic should know this. How could a mechanic tighten a crank pulley to 30lb/ft. and think that that's acceptable? Get a new mechanic.
Anyways, install was a breeze other than lining up the recess for the key on the pulley. Just take your time and ease it on. You'll know when it's on because the pulley will line up with the other pulleys (the belt line) and it will feel snug.
Old Jul 7, 2006 | 02:25 PM
MrKaira's Avatar
MrKaira
Really MrZ31
well, he sure hasnt done any work after the car broke down... he installed my exhaust, but that vibrates like hell now (i think cause its not welded) and i am gonna take it to my mechanic here that specializes in exhaust to see what he can do. For his part, he did torque it down to 50 lb ft, cause he thought 30 was way too low, but it still was not enough. However, the instructions still said 36 lb ft. Oh well, I'll see what the lawyer man says and go from there, cause damn I would love to have that $4k back.
Old Jul 8, 2006 | 12:54 AM
ryanmac516's Avatar
ryanmac516
i like boobies
thanks alot everyone all this info is very helpful and yea any help would be greatly appriciated i work in metairie at outback and live in destrehan so any help would be great i will figure out what days i can get off on tuesday i will be off on monday but need to go get insucance yall let me know when you are free thanks again
Old Jul 9, 2006 | 09:37 PM
ryanmac516's Avatar
ryanmac516
i like boobies
i am pretty sure i will installing it tommorow sometime at 12:00 noon wish me luck
Old Jul 17, 2006 | 01:24 PM
ringfingur's Avatar
ringfingur
How did you make out installing the pulley? I attempted this weekend but was unable to get the crank bolt off. It seemed that every time i would torque on the bolt, the pulley still had give (even when the car was in sixth gear as recommended). I'm using a large 1/2in drive wrench to remove the bolt and it still refuses to budge. The KJR instructions recommend resting the car down on the ground with the wrench secured against the ground as well and cranking the engine!! Doesn't really sound like a good idea to me. Has anyone found an alternate way of either securing the pulley or removing the crank bolt in general?
Fixxxercask
Nov 9, 2015 11:10 AM
2ndchanceZ
Oct 26, 2015 08:03 PM
