Cipher V1.03 Update
Old Jul 12, 2006 | 04:28 AM
UpRev's Avatar
UpRev
Default Cipher V1.03 Update
We've been getting a lot of emails asking about the recent Cipher update, so here's a quick run down of the new features.
New work support features include…
Adjust Ethanol Mixture Ratio:
For Flex Fuel capable vehicles, this feature configures the ECU to compensate for different ethanol mixtures. Changing the settings will alter the fueling of the vehicle.
Fuel Pressure Release:
Discharges the pressure in the fuel line by disabling the fuel pump. This increases the safety of fuel line work by releasing built up pressure and limiting the potential for fuel spray.
Fuel Injection Test:
Test and troubleshoot the injection system by manually controlling the injector pulse length while monitoring timing.
Coolant Test:
Test and troubleshoot engine operation issues by forcing the ECU to read false values for the coolant temperature sensor.
Cylinder Power Test:
Provides troubleshooting capability by turning individual cylinders on and off as needed.
** This one’s my fav. It’s great for isolating cylinder specific failures like bad injectors, coil-packs, harnesses, and a ton of other stuff.
More info at www.UpRev.com
-Jared.
Whiskers1996
Tuning
Aug 1, 2020 04:09 PM
Workshop12
Mar 23, 2020 01:45 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
