What to get 1st?
Old Jul 21, 2006 | 07:25 PM
SunsetSunrise's Avatar
SunsetSunrise
still confused.
Do I need Iso or not?
Old Jul 21, 2006 | 07:35 PM
xedes's Avatar
xedes
Originally Posted by SunsetSunrise
still confused.
YES!
Old Jul 22, 2006 | 12:53 AM
Eazzy's Avatar
Eazzy
I apologize--Dawned on me u live in NY---U can use the Coolant Control Valve (CCV) if u want---Below 55 degrees u open it.
The Copper Throttle Body heater can be used in either warm or cool climates eliminating having to mess with the CCV
info@motordyneengineering.com 661-993-5111 They will explain everything
Old Jul 22, 2006 | 01:25 AM
ZRider07's Avatar
ZRider07
Get the spacer.
Old Jul 24, 2006 | 08:13 AM
SunsetSunrise
I guess Iso it is.
Would I be able to install it myself?
Old Jul 24, 2006 | 08:51 AM
Eazzy's Avatar
Eazzy
Originally Posted by E***zzzzy
Piece of cake --- Make sure u have a accurate in/lb torque wrench and even taking your time it should take like 3 hours ---I can do one in an hour and a half---I would suggest u get the copper throttle body heater that fits between the plenum intake and TB----also from Motordyne
Also a good time to have ur Upper plenum Powder Coated for detail --Mines black but iv had them done in red, chrome color,Yellow,---Its ur call
Repete!!!^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^And Yes---In-Lbs ---otherwise breaky wakey
Old Jul 24, 2006 | 08:57 AM
03performz's Avatar
03performz
5/16th Isothermal plenum spacer. You can install yourself, just take your time. The instructions are very straight forward. Note: you MUST have a torque wrench, and notice that the torque specs. are in INCH/lbs. not foot lbs.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
_koubie_
Sep 20, 2015 06:34 PM
