What to get 1st?
Old Jul 21, 2006 | 06:28 AM
SunsetSunrise's Avatar
SunsetSunrise
Default What to get 1st?
I know these questions were asked a million times, but I still cant make my decision. Even after searching the forum threads I decided to ask you guys.
I have '03 6mt touring with a Pop charger only.
I was thinking of getting one of the following items:
1.Ichiba Test Pipes
http://hpautoworks.chainreactionweb....oducts_id=1106
Found them for $169
2.Ichiba Y pipe
http://hpautoworks.chainreactionweb....oducts_id=1553
$189
3.UR pulley
http://hpautoworks.chainreactionweb....roducts_id=544
$189
Which one of these three would you recommend getting 1st?
What is more bang for the buck?
What will not void warranty?
Is it a good idea to get Test Pipes & Y Pipe together and save money on installation?
Any recommendations would be appreciated.
Old Jul 21, 2006 | 06:46 AM
Eazzy's Avatar
Eazzy
Get a Motordyne 5/16 plenum Spacer then an exhaust system---Screw the pulley----Want more rev for ur buck ???? Get a JWT flywheel
Old Jul 21, 2006 | 07:00 AM
SunsetSunrise
Wont the plenum spacer void the warranty?
I would get the JWT flywheel, but the dealer just replaced my tranny and the clutch for free. Not sure I want to mess with that are of the car yet.
Alberto's Avatar
Alberto
Cranky FI Owner
I would do the test-pipes without a doubt.
Old Jul 21, 2006 | 07:06 AM
Metal Heart's Avatar
Metal Heart
Test pipes sir.
Old Jul 21, 2006 | 07:36 AM
SunsetSunrise
Would you go with ichiba test pipes?
Is pop charger test pipes & plenum spacer a good combination for performance and sound?
Old Jul 21, 2006 | 07:48 AM
Eazzy's Avatar
Eazzy
Cant see as how it can ---All ur doing is correcting a proven flaw in Nissans Plenum Design----certainlly less than droppin a cat. And keep in mind that a NA motor needs a certain amount of exhaust back pressure. With the spacer u WILL notice a difference!!! Just my humble 2 cents.
Old Jul 21, 2006 | 08:57 AM
SunsetSunrise
Makes sense!
Thank you.
I guess spacer it is.
Do you think I would be able to install it myself?
Old Jul 21, 2006 | 09:06 AM
Eazzy's Avatar
Eazzy
Piece of cake --- Make sure u have a accurate in/lb torque wrench and even taking your time it should take like 3 hours ---I can do one in an hour and a half---I would suggest u get the copper throttle body heater that fits between the plenum intake and TB----also from Motordyne
Also a good time to have ur Upper plenum Powder Coated for detail --Mines black but iv had them done in red, chrome color,Yellow,---Its ur call
Old Jul 21, 2006 | 09:36 AM
pingrr's Avatar
pingrr
I would definatly go with a new plenum or spacer next
Old Jul 21, 2006 | 09:50 AM
masterj26's Avatar
masterj26
i would definetly go test pipes or the md spacer
Old Jul 21, 2006 | 10:44 AM
Noah@AAM's Avatar
Noah@AAM
spacer!
Old Jul 21, 2006 | 11:28 AM
SunsetSunrise
so far Spacer is winning!
Old Jul 21, 2006 | 11:31 AM
masterj26's Avatar
masterj26
if you want the MD spacer you can get it from partshippers w/ free shipping saves you a little $
Old Jul 21, 2006 | 01:35 PM
SS350Z's Avatar
SS350Z
How does a plenum spacer compare with a full plenum replacement, and how much for a plenum spacer?
Old Jul 21, 2006 | 02:32 PM
SunsetSunrise
Iso thermal or basic?
Old Jul 21, 2006 | 02:38 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
anthing can void your warranty, even wheels
that is totally up to the dealer
all the mods you mentioned are worthwhile, and I'd also add a spacer to the mix too
Old Jul 21, 2006 | 02:39 PM
masterj26's Avatar
masterj26
if you have any questions about the md products you can always call and talk to Tony. In the cold weather you might want the copper iso-thermal
Old Jul 21, 2006 | 04:38 PM
SunsetSunrise
I am in NYC so it does get cold.
I guess Iso thermal it is.
Old Jul 21, 2006 | 06:28 PM
Eazzy's Avatar
Eazzy
Actually the copper TB spacer ---Isolates the plenum, keeping it cooler ---Motor dyne offers the Coolant Control Valve that allows to to heat or not heat the plenum---You DONT need that. With the Copper TB heater ---u keep the TB warm and the plenumum cool,,,Ideal for hot climates
And to address the other question as far as pros and cons ---Spacer/Plenum----Spacer is cheaper, If 5/16 no need for modded strut and Dyno tests have shown the MD increases HP more than AAM spacer,Crawford Plenum, or Kinetix Octopus ( Winter 2006 sport Z Magazine )
And ---Hey ---I run one and am happy as Crap
