A/T Pros. 1 ?
Im going to be upgrading my valvebody with F.I version.when I remove the V/B were . do I refill the Tranny fluid when re-installing.We dont have a dip-stick so any help is appreciated.
Thanks
Thanks
Thanks
Thanks
Watching tthe Nissan tech who did my change and refill.....there were two hoses connected to the underside of the Z.....both connected to this machine.....so it had to be a pump/flush system......my Z was put on a lift to connect the hoses....
probably not much help, but thats all I've got.
Where did your dipstick go?
You can refill through the tranny cooler inlet/outlet hoses. The AT cooler is integrated into main radiator on the AT Z cars. Look for two black rubber hoses 2/3 of an inch thick at the very bottom of the radiator (left side if I recall).
I believe that you will need some sort of oil pump though. Also, measuring the level of the ATF on our car is a *****. I am still struglling with that.
Minda
Minda
