Good News: ECU outlook good
Old May 12, 2003 | 01:14 PM
  #181
zland's Avatar
zland
Sport Z Magazine
Originally posted by Chebosto
UPDATE UPDATE UPDATE
Check the Sticky Thread GREAT NEWS!!!!!!!!!!1
Ok, I admit I am lame but what is the "Sticky Thread "? I want to read about the update...
Old May 12, 2003 | 01:20 PM
  #182
Chebosto's Avatar
Chebosto
5/12/03
We felt that the Magnaflow exhaust will work any better than stock, so we abandoned the idea.. from installing it and running it for a while, its appears to be WORSE than stock...
here's the kicker..
We're done with the programming.
Conserning the ignition map and fuel maping. we got the ratio to around 12.5 air fuel and +40 degrees timing. He said 40 is a bit much, so he's going to retard it little. Stock is 25-26 degrees (I think). =) The main changes to the fuel/air program is to the top end of the RPM band, stock is around 10.5 and we leaned it out a bit to the end result of 12.5
NO CEL with the Test pipes (which will go on sale soon as well, along with a tuned Ypipe to go along with the test pipes as a option)
Tadashi claims that the stock airbox is a very good free flowing intake, possibly even better with a velocity stack addon would beat all the other intakes... they are planning to make that soon.
More info about the infamous 'dialing back' of power...
the deal is that the stock ecu bases some of its fuel/air input through the oxygen sensors in the car. The computer will try to follow the pre-set map from the factory. and uses feedback from the o2 sensors to do minor adjustments to the ignition/fuel mapping. So when you put the new intake system (aka Injen) the computer senses much more air flow than the stock mapping so, with this happening, the computer goes to the feedback value that's stored in the fuel/ignition timing maps to try to put it back stock levels.. which means.. the car is inputting RETARDATION in the timing map. its' taking away the ability for the engine to fire with the leaner air from the higher flowing intake.. so we're just removing/reducing that feedback value.. if you dont believe me.. Tadashi will post a full technical report later on at his company's website.
The modified ECU program will be released as a 'general' program. it will ADAPT to your mods and will allow the mods you put on your car to get a consistant power gains over time, w/o the ECU retardning the power back.... So, with that. this ECU program will work with a bone stock Z, a slightly modified Z, and/or fully decked out intake/plenum/header/cat/ypipe/catback'd Z too....
For boost applications, when they become available, they will have a program for that as well.
If you can find a spare ECU, TechnoSquare can make that computer to work with your Z.
Well happy day...
hope this clears up some of your questions... or brings up more questions.. please post your comments on the LONG version thread in my sig....
thanks--
Cheston
  #183
EWOOD420's Avatar
EWOOD420
will they take an 02 3.5se Altima ecu to tune. I'm sure they are very close to each other.....
Old May 12, 2003 | 01:25 PM
  #184
zland's Avatar
zland
Sport Z Magazine
Wow, sounds like ther is some benefits to all this work you did. Can you be more specific on what the changes it would make on a stock 350Z?
Old May 12, 2003 | 01:26 PM
  #185
Chebosto's Avatar
Chebosto
they might be similar in flash memory.. but highly doubt the programs or the interface are close to each other
Old May 12, 2003 | 01:39 PM
  #186
EWOOD420's Avatar
EWOOD420
I see how it is..... j/k
Hey you never know right..... they put in the same motor
thanks
Old May 12, 2003 | 02:12 PM
  #187
Zspot's Avatar
Zspot
When do you estimate the ECU will be available ?
Old May 12, 2003 | 02:14 PM
  #188
Ez350's Avatar
Ez350
Did they come up with a final HP number that you would feel comfortable publicizing? And when do you feel like this will be available for purchase?
Old May 12, 2003 | 02:19 PM
  #189
Chebosto's Avatar
Chebosto
We will be doing a DynoJet pull to get a 'standardized' hp # claim sometime this week to get a baseline. and sometime next week for with the modded chip alone, and with the exhaust mods.
pricing is not yet set..
Old May 12, 2003 | 04:15 PM
  #190
Traffic's Avatar
Traffic
Could you define 'adapt'? What I mean to say is, let's say I have 264 cams, hi-compression pistons, plenum, headers, midpipe and exhaust. Then I get the ECU. What would it do in the presence of these mods...are you saying I could see yet more HP than what is currently being seen?
Old May 12, 2003 | 06:06 PM
  #191
Chebosto's Avatar
Chebosto
yes.
but then with the cam, the higher compression, i would suggest you get it tuned to your specific car to adjust the timing even more so with the higher compression... but in general. yes.
Old May 12, 2003 | 06:17 PM
  #192
XBS's Avatar
XBS
Veteran
this company is going to sell ALOT of ECUs i hope the forums members get a discount
GETTING SO EXCITED
Old May 12, 2003 | 06:36 PM
  #193
Brad4rdHay's Avatar
Brad4rdHay
(Im stupid)
Why does decreasing the fuel make the engine more powerfull? Shouldnt gasoline have a chemicaly optimum air/fuel mix that would allow for maximum combustion...i.e. would be used on every car on the market?
Also, if I get ths ECU, then get a freer flowing intake, the ECU wont go into its own new fail safe mode when the newly programed air/fuel mix is disturbed?..if its still the same program.
Also, whats ignition timing and why is it measured in degrees? Is it how often the spark plugs fire?
Old May 12, 2003 | 06:43 PM
  #194
MannishBoy's Avatar
MannishBoy
Too rich, and you lose power. The factory sometimes tunes WOT to run richer to avoid detonation, but the trade-off is the loss of hp. Adding fuel cools the mixture some, which causes the decreased chance of detonation or knock.
Old May 12, 2003 | 07:00 PM
  #195
FLY BY Z's Avatar
FLY BY Z
Yes, it is when the plugs fire in relation to the location of the corresponding piston.
Old May 12, 2003 | 07:42 PM
  #196
Brad4rdHay's Avatar
Brad4rdHay
The ECU sounded like a great idea at first, but now (being the constantly learning car nut that I am) it seems like were treading in dangerous waters. The engieers at Nissan know what the **** their doing, even if they are playing it safe. But still, im getting worked up about changing the akerman angle of the suspenion a few mm which will throw off the steering, and now were talking about changing the way the engine functions.
Now Im not that dumn. Aftermarket ECUs arn't brandnew, but I dont want to have a situation were we have it in the hands of overzealous tuners (arnt they by nature) who wll use their considerable skills to get every last hp out of the engine but leave us with something thats less reliable. This seemed to have happened with the new E46s M3s.....alot of problems with detonation (i think thats what it was). At leat then it was covered under warrenty. If I have a problem with my engine down the road, Ill get a big "sucks for you" from Nissan.
Sory to make this sound like a rant, its not, im just a tad anxious. More of a "prove me wrong" which I'm sure many are capable of...
Old May 13, 2003 | 01:20 AM
  #197
XBS's Avatar
XBS
Veteran
to each his own
Old May 13, 2003 | 02:41 AM
  #198
Brad4rdHay's Avatar
Brad4rdHay
Seriously, I will jump all over this is someone can prove to me that changing the air/fuel mix and ignition timing wont affect longevity/reliability. If its as safe as an exhaust, ill be on that ECU like white on rice.
I wont buy it if its a "well have to wait see"
Old May 13, 2003 | 06:45 AM
  #199
ITR#203's Avatar
ITR#203
It is true that making the mixture leaner and advancing timing puts you closer to the edge pre-det. BUT have you seen the stock fuel-air ratio? He claims that it is 10.5:1 and this is backed by Amuse's numbers, who I believe got around 10.7:1. This is WAY too rich. Even 12.5:1 is on the rich side, which I dont mind for safety reasons, but most guys like to tune their cars at around 13.4-13.8:1, unless it's a forced induction application. Sure, you can go even richer than this but I wouldnt recommend it.
I dont suspect that this will be a "on the edge" ECU, where if one thing goes wrong (for example, 90.5 octane gas or 90 degrees outside temp), it will start destroying your engine. It's not doing anything different, its just that Nissan is a bunch of wusses who put in a ECU that was way too anti-mods, ran too rich, and backed down ignition timing toomuch, too quickly. In my opinion, its just fixing these problems. There should be NO adverse effects.
Old May 13, 2003 | 06:46 AM
  #200
Chebosto's Avatar
Chebosto
if you have worries about changing the timing and a/f mixtures and longevity, you should ask some of the JWT/hondata/Gforce owners.. Technosquare (formerly Gforce Engineering) programmed thousands of turbo Supras/MR2s and still do. This isnt you're hole in the wall tune shop, Tadashi and crew are quite well known in the ECU tuning business and have been approached by big name race companies... (*cough* NISMO *cough*) but more importantly he is an enthusiast like us and he just wants good products, none of this JET Chip crap that all they do is slap a sticker on, ECU modifications have been safe in the past and i wholly believe in this one, otherwise i wouldnt have trusted them with my car for so long...
I'm not saying believe me, but once other people get it and have the chance to see what i've seen, then maybe people will get more confident. everyone is skeptical on ECU work.. same deal happened with the Maxima community a few years back when Tadashi produced the ecu for that too... just time will take to see the end result..
