Radiator Cooling Plates
Old Aug 22, 2006 | 05:40 PM
BlackSpec02's Avatar
BlackSpec02
Default Radiator Cooling Plates
I've been pretty curious about these lately... sure they look pretty under the hood and smooth it all out a bit.
But do they REALLY help keep engine temps down, etc.?
What affect would they have on a bolt on -z vs. forced induction?
Worth it for 50-100 bucks?
Opinions, experiences, preferences, comments... whats the deal with these things?
Old Aug 22, 2006 | 05:45 PM
woodstock300s's Avatar
woodstock300s
i got a cf one it just looks real nice but i dont know if it helps cooling either i would assume it does
Old Aug 22, 2006 | 06:29 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
There are a few different schools of thought on them...
Most of them make it a little trickier to open the hood... Its hard to get the hood release when they are in place (have to reach for through less of a space)...
Some have said that they block air from going over the top of the motor (plenum etc)...
But they do look cool yes...
Old Aug 22, 2006 | 08:35 PM
Eazzy's Avatar
Eazzy
Anytime u can divert more air THROUGH the radiator rather than over or under the radiator ur better off. Point is it sure dont hurt
Edit: Ya --as Jason says ---It takes a day or 2 to get used to the release----I had to machine my Greedy aluminum one out to clear all the Kaminari Hood Crap
Old Aug 22, 2006 | 09:25 PM
BlackSpec02
Good to know. Any that are known to be easier or harder to get your hood open?
Anyone know of any place/ brands that have a good price on em? cf/aluminum... doesnt matter to me.
Old Aug 23, 2006 | 04:59 AM
Eazzy's Avatar
Eazzy
Greddys is reasonably priced and funtional--Aluminum-- Have to put a polish to it every so often
Old Aug 23, 2006 | 08:22 AM
MustGoFastR's Avatar
MustGoFastR
I like this one:
http://www.i-m-racing.com/aucafirapa35.html
Nice CF and has a little scoop that directs air into the intake as well. Haven't gotten one yet b/c if I do, I know I'll just have to start getting more CF stuff...
Old Aug 23, 2006 | 09:00 AM
SpeedRcr's Avatar
SpeedRcr
they sell on ebay cheap
Old Aug 23, 2006 | 12:24 PM
BlackSpec02
Based on what jason said im wondering if it's better to have one and have air going through my intercooler and radiator or over the top of the engine... i have the stillen stage 2 and it gets hot under there!
Old Aug 23, 2006 | 12:28 PM
Jason@Performance
Performance Nissan
Air is going to go over both when not in place...
Some air will go around the front of the engine after going through the radiator but not so much forced up above...
Old Aug 23, 2006 | 01:01 PM
BlackSpec02
So which is better for my blower set up. Hey which one of you guys at performance has the stillen Z? Does he use a cooling plate?
Old Aug 23, 2006 | 01:07 PM
Jason@Performance
Performance Nissan
Tony has the stillen supercharger, unfortunatly no longer with the company...
I think he has a carbon fiber cooling plate of some kind... he has it mainly for looks...
Old Aug 23, 2006 | 01:12 PM
BlackSpec02
Oh okay, cool, well thanks for the info.
Old Aug 23, 2006 | 01:24 PM
Eazzy's Avatar
Eazzy
Well --with like the Motordyne spacer where u have the nylon spacers between the upper and lower plenum ----Upper plenum heat is greatly reduced---I kinda like rammin as much air as possible thru the coolers as I can ---To the point that I put side diverters on mine
Although as u can see by my Avitar, Im Scooped so that solves my upper heat prob
Old Aug 23, 2006 | 06:38 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
Cooling plates on the Z don't do much of anything but look cool.
If you look at the hood, there is a seal that goes across the top of the radiator so it is unlikely much air, if any, would travel over the top.
Chris
Old Aug 24, 2006 | 12:07 AM
BlackSpec02
Right.... but i have the stillen hood that does not have that.... and as i was stating it does get pretty dang hot under my hood... my temp gauge never gets too high or anything but with the roots blower im still sure than my under hood temps are hotter than normal.... so im wondering if it would be more effective to keep my engine cool by forcing the air through the intercooler and radiator or by letting the air come across the top of the motor... i also have a varis duct in front of my pop charger and heat shield which should help intake temps a bit.
Old Aug 24, 2006 | 07:18 AM
HyperSprite
Mad Scientist
Ok, got it
Air going over the top of your motor is far less effective than air going through your radiator and coolers. For you, a cooling plate would be beneficial. If you are concerned about under hood temps, cutting out the scoop and taking the rubber seal off just in front of the windshield would probably bring up the air flow quite a bit without sacrificing water cooling.
Chris
Old Aug 24, 2006 | 12:15 PM
BlackSpec02
SO you mean effectively making my cowl functional... ?? cool.
Twenty4
Jan 17, 2016 01:20 PM
kyin
Oct 15, 2015 05:54 AM
SharX59
Sep 30, 2015 10:54 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
