Ahh.. problem! Something sounds like its dragging..
Old Sep 3, 2006 | 02:57 PM
dingobiatch's Avatar
dingobiatch
Default Ahh.. problem! Something sounds like its dragging..
Okay, so I got my mrev+ and 5/16 spacer installed last week (and I had Kinetix HFC's installed about two weeks before that), and the strangest thing is happening. Whenever I go over a speedbump, or I'm going up an incline where the road is bumpy, it feels like something is grinding against the bottom of my car. This only started happening after my mrev+ and 5/16 spacer install.
It feels like its directly under me. My first thought was that maybe the HFC's were grinding against the ground, but I checked underneath the car, and there is NOTHING that could be low enough to. This is really bothering me though, because it feels like the car is being damaged..
Any ideas? I'm going to take the car down to the local shop who installed the plenum mods, see what they think, but until then, trying to get some advice..
Old Sep 3, 2006 | 03:05 PM
ouch1011's Avatar
ouch1011
If anything is grinding on the ground, you will see scrape marks on whatever is dragging.
Old Sep 3, 2006 | 05:45 PM
dingobiatch
Well, yes, but I can't see anything. Basically, it seems as if nothing is dragging on the ground, and that maybe something else is causing it to feel like that. I think I'll have to get the shop to check it out though.
Old Sep 3, 2006 | 07:11 PM
Z BOY's Avatar
Z BOY
kinetix hfc are notorious for hitting the heat shields or underbody of the car. nothing a little focused hammering won't cure.
Old Sep 5, 2006 | 01:16 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Maybe strut bar rubbing against hood?
Old Sep 5, 2006 | 08:56 PM
Z BOY's Avatar
Z BOY
if he feels it directly under him, its prolly the cats. maybe the extra air flowing thru the plenum is vibrating the cats more than usual.
Old Sep 5, 2006 | 09:10 PM
plumpzz's Avatar
plumpzz
i once got a piece of tree stuck under there and i suffered the same problem lol.
Old Sep 6, 2006 | 04:10 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
also if they or anyone messed with the black plastic cover that goes under the engine and all the bolts didnt get put back in, well when you drive it will come down and scrape stuff but when you stay still, then it stays up mostly...
i would check that plastic cover, does it sounds like plastic or metal scraping, they make two totally different sounds.
Old Sep 8, 2006 | 08:40 PM
dingobiatch
Feels like metal scraping. It feels like the cats or something is hitting the, but that seems impossible based on how high up they are from the ground (I'm not lowered at all).
Old Sep 8, 2006 | 11:22 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Something caught in the dust shields behind the brake rotors?
Obadabot
Jun 18, 2023 11:31 PM
Uriyo_
Sep 8, 2021 08:46 AM
