Forged Pistons And Rods
Old Sep 8, 2006 | 01:25 PM
nismo350zj's Avatar
nismo350zj
Question Forged Pistons And Rods
Ok so ive been looking and the cheapest low compression forged pistons and rods are the nismo ones. Now i know for a fact that you can get custom made ones that are cheaper, so are there any cheaper ones out there? What do you guys use? And does anybody actually use the AEBS stroker kit or is there a cheaper stroker kit out there also?
Old Oct 6, 2006 | 05:48 AM
InjectedPerf's Avatar
InjectedPerf
Injected Performance
We have the AEBS stroker kit currently running in our Z with a GT42R single turbo. There are cheaper stroker kits but they are not available yet. We will have motor packages with these kits in the near future.
Old Oct 6, 2006 | 06:43 AM
chimmike's Avatar
chimmike
if the cheapest ones you can find are Nismo, you're not looking hard enough.
Eagle makes con-rods, and Arias makes low compression pistons, and the combo is definitely cheaper than Nismo.
Also, the AEBS stroker kit has had some horrible reviews....I would resarch it.
Old Oct 6, 2006 | 07:08 AM
InjectedPerf
AEBS had some bad reviews because they did not let myself and one other guy know that you have to modify the short block. They actually assembled mine as I didn't want any chance of failure (didn't want be blamed for an $8K motor failing) and didn't fix the problem. So far I have not had any problems. They were definately not the easiest to work with and it took a rediculous amount of time. They did not supply any head gaskets and blamed Cometic for the delay. We had to modify our own gasket to make it work. Other than that, the motor has prefered as I expected and with such a big turbo I bet it will out spool some of the smaller turbo 3.5L's.
Old Oct 6, 2006 | 04:35 PM
VIZAGE's Avatar
VIZAGE
This is slightly off subject but Crower claims to have a 4.1 stroker kit. Like to see that on a TT Z. They say it takes 6 to 8 months to get.
Old Oct 6, 2006 | 10:59 PM
radiologue's Avatar
radiologue
I should have a built engine with the Crower 4.15L stroker and APS TT completed in the not too distant future. Reportedly the engine is already built but finishing up on some body details before it is put in the car.
Old Oct 7, 2006 | 06:40 AM
bullseye's Avatar
bullseye
Maybe it's just me, but I flinch everytime I read the words piston/rod/stroker kit in the same sentence with the words cheap/cheaper/cheapest.
Old Oct 9, 2006 | 08:55 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Stroker: http://www.z1auto.com/prodmore.asp?m...ne&prodid=2080
current lead time is 6-8 weeks
As for lower priced forged internals, very easy - Eagle rods and Wiesco pistons - total price would be just under $1200
aboodi
Oct 28, 2015 02:07 PM
pr_350z
Oct 1, 2015 05:03 PM
