06 Motor swap ?
Old Sep 15, 2006 | 01:39 PM
03_ppw350z's Avatar
03_ppw350z
Default 06 Motor swap ?
im about trade my motor out of an 06 for a fully built motor coming out of an 03. i need to know if all the sensors are the same and if the wiring harness is the same. i need to know if my 06 computer will plug right into the 03 harness? anyone know anything? thanks in advance.
Old Sep 15, 2006 | 02:23 PM
superchargedg's Avatar
superchargedg
Damn Noobs
well the only thing i know for sure is the o2 sensors are different,early years used narrow band and newer use wide band,so i would say you better get the right ecu.plus if its a revup down to a non revup of course the computer,s are not the same.
Old Sep 15, 2006 | 02:26 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
You might want to talk to somebody from technosquare... I'm pretty sure the ECUs are not directly compatible.
+1 on the widebands on the 06, not to mention the exhaust cam variable timing must add an additional sensor, at least I would assume so.
Old Sep 15, 2006 | 04:31 PM
03_ppw350z's Avatar
03_ppw350z
can i swap jus the bottem end and block with my heads and valvetrain or is there a piston clearence issue ?
Old Sep 16, 2006 | 06:49 AM
ALong's Avatar
ALong
You will need the engine wiring harness and ECU, 06 has VTC on both intake & exhaust cams, the 03 only has VTC on the intake cam, computers and wiring harnesses for these motors are both different because of this.
Old Sep 16, 2006 | 06:55 AM
Q45tech's Avatar
Q45tech
The Clean Air Act forbids swapping older more polluting engines into a newer vehicle.............is this for racing/off road use only?
Reselling such a vehicle may be problematic and open you up to future litigation to return to oem as built.......emission fraud.
Old Sep 16, 2006 | 07:14 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
You WILL need the wiring harness and the ECU, they are different
Old Sep 16, 2006 | 09:27 AM
03_ppw350z's Avatar
03_ppw350z
thanks for the responses but can anyone tell me if i can jus use the botom end from the 03 including block and bolt my 06 heads valvetrain and front timing covers?
Old Sep 16, 2006 | 12:07 PM
ALong's Avatar
ALong
It should work, however the 06 has lower compression pistons comparted to the 03, dont know if the valves and valve clearance are different, as long as the valve clearance is ok, should work fine.
Old Sep 18, 2006 | 06:51 PM
Nismo350ZRT's Avatar
Nismo350ZRT
I've asked this question many times and the answer from the engine gurus is yes, you can bolt your revup heads on a non-revup block. The blocks themselves are identical. If the 03 built block has low compression pistons, you will not have any clearance issues.
Old Sep 18, 2006 | 08:46 PM
thawk408's Avatar
thawk408
The revup motors are the same CR as all the other engines. I dont know where you heard that the revup has a lower CR.
Old Sep 19, 2006 | 10:43 AM
LODOSS's Avatar
LODOSS
yah.. i second that
Old Sep 19, 2006 | 10:46 AM
97supratt's Avatar
97supratt
Originally Posted by LODOSS
yah.. i second that
+1
Old Sep 19, 2006 | 11:39 AM
slinksZ's Avatar
slinksZ
dang Q45 clean air act in GA. That would have been the last thing on my mind during a engine build up. hell down here we do not have to worry about state inspections.
SharX59
Sep 27, 2015 09:23 AM
