Rear Axle Clicking
Old Sep 19, 2006 | 07:01 PM
Fear's Track 06's Avatar
Fear's Track 06
Default Rear Axle Clicking
so my rear axle sounds like its clicking when i floor it. ive been reading about this on the forums and was wondering who else here has this noise and when it happens. like i said it only happens when i floor it. anyone else?
Old Sep 19, 2006 | 07:31 PM
Jenn350Z's Avatar
Jenn350Z
OMG!! I think I can actually help on this one
As found in the "Top 100 Common Questions" , Page#2
Link: https://my350z.com/forum/showthread....=axel+clicking
Q: I hear a clicking sound sometimes. What is that?
A: Beware, however, of a slight metallic clicking sound coming from the rear of the car. It is due to the rear axle not being properly lubricated. If your car has this problem, you will usually hear this clicking sound when (1) in an enclosed space or driving near a hard wall, (2) driving without radio and with the window down (try turning off A/C if you still aren't sure), and (3) starting to move from a halt. The clicking sound is more pronounced while turning, or so it seems.
If you have the clicking, your car is due for a "Technical Service Bulletin" or "TSB" repair for rear axle clicking, which is covered under warranty. Take it to a dealer, and don't leave until they agree to fix it.
Did I help??
Old Sep 19, 2006 | 08:27 PM
kramykram's Avatar
kramykram
lol search is an amazing thing let alone being a sticky as said above
Old Sep 19, 2006 | 09:13 PM
Zincognito's Avatar
Zincognito
HAHAHAHA.........thats too funny!
Old Sep 19, 2006 | 10:27 PM
Casanova's Avatar
Casanova
LOL - - take it to dealership... dont forget your Nuts (lok)
They fix it right up... and if they dont.. punch them in the face.
Old Sep 20, 2006 | 12:49 AM
Armitage's Avatar
Armitage
I've also read that the dealer fix is only temporary and the problem will return in approx. 2-3 months. From what I've also read, the problem is not dangerous in that something will break.
Old Sep 20, 2006 | 07:22 AM
Jenn350Z's Avatar
Jenn350Z
But as soon as you get it done you have a 1 year/20,000km warranty against it happening again
Old Sep 20, 2006 | 10:40 AM
kdogg24's Avatar
kdogg24
I just had my Z in the shop getting the rear axle click repaired. Simple process for any Z under warranty.
Just call your local dealership and explain the problem, most of them know exactly what it is and how to fix it, they will order the needed parts to do both sides of your rear axle. Make an appointment to take your car in, and it should only take about 1 1/2 hours to finish.
Old Sep 20, 2006 | 11:03 AM
Armitage's Avatar
Armitage
Oh wow! So if it happens again within that timeframe... do I get the warranty extended?
Old Sep 20, 2006 | 04:46 PM
seoulcity's Avatar
seoulcity
yeah i just started hearing my axle click.. have 17k miles on my 2005.... taking her in monday... =) and get my tps sensor fixed too..
Old Sep 20, 2006 | 05:44 PM
Fear's Track 06
when does this happen to you guys. it happens when i floor it.
Old Sep 21, 2006 | 02:11 PM
reptile718's Avatar
reptile718
I have a creaking and clicking coming from the rear end, then again my Z does have 60k on her. It happens when I stop, go, turn or hit a bump. I made the appointment as suggested and was quoted $160 total for this job. They will warranty this service as mentioned. Wish me luck, cant wait to get rid of those annoying sounds. I have to drop her off tonight for a sleep over at the dealership so they can start working on her bright and early 2morrow
Old Sep 21, 2006 | 08:47 PM
Armitage's Avatar
Armitage
I hear it when starting from a stop. I don't hear it once I'm in motion.
Old Sep 21, 2006 | 09:12 PM
DIGItonium's Avatar
DIGItonium
Mine returned and it is so bad it sounds like a bucket of screws when i hit small bumps at low speed, pulling into the drive way, starting from standstill... etc. I'm going to address the issue again once I get new brakes and tires.
Old Sep 23, 2006 | 07:17 AM
Peking's Avatar
Peking
So what if you are like me with a BASE version Z, and have LSD...
I have the Cusco LSD, which means I have the VLSD axle stubs and not the BASE axle stubs...
Will the Nissan dealer still replace/fix my clicking sound?
Old Sep 23, 2006 | 04:09 PM
Armitage's Avatar
Armitage
Don't remember about the 06's, but 03-05 does not have an LSD. It has an open differential.
Old Sep 23, 2006 | 04:37 PM
undrgnd's Avatar
undrgnd
LSD as in Limited Slip Differential? I believe my 2005 does have one, unless the sticker is lying. I have the 35th Anniversary.
Old Sep 23, 2006 | 05:05 PM
Armitage's Avatar
Armitage
Yours does yes, I was talking to the poster above mine.
Old Sep 23, 2006 | 06:19 PM
Peking's Avatar
Peking
Huh? Yes my 2004 Z is a Base version that originally had no VLSD that came on the other trim levels... Which is def. fine, I don't like Viscous LSD's...
Anywho, I have the Cusco 1.5 Way LSD with VLSD Axle Stubs which are needed for use with that LSD.
My concern earlier was that the dealer was not going to replace what was needed because of my aftermarket LSD and non-Base version axle stubs.
Though after visiting the dealer today, it is the outer axle and wheel bearings that are lubed and/or replaced.
So I shouldn't need to worry and I am not going to mention my upgrades in the rear unless it needs to be.
Old Sep 24, 2006 | 02:02 AM
Armitage's Avatar
Armitage
^Ah, ok. Thats what I figured. Thanks for clarifying though. =)
