How to clean the Throttle Body...
Old Sep 23, 2006 | 01:25 PM
halfass872's Avatar
halfass872
Default How to clean the Throttle Body...
I realize this is a fairly elementary question. But to clean the throttle body, is it just a matter of removing the intake piping and wiping the inside surfaces with carb cleaner?? If i remove the Throttlebody to clean easier can i re-use the gasket?? Thanks!
Old Sep 23, 2006 | 02:11 PM
undrgnd's Avatar
undrgnd
When I took the TB off to replace the plenum, i used acetone and a paper towel. It worked great. Make sure you disconnect the battery before you unlpug the electrical connector from the TB. Also, make sure NOT to push on the butterfly plate at all or you may have to perform a learning procedure. I reused the gasket, torqued to 90 in-lbs, no leaks, no problems, runs great. Connect the battery AFTER everything else is hooked up.
Old Sep 23, 2006 | 02:20 PM
halfass872's Avatar
halfass872
Great, thanx! Unfortunatly i already did it and i didnt unplug the battery....but at no time did i turn on the key while it was removed, so hopefully when i go back out tonite i won't have any problems. If so how hard is the "re-learning" procedure for the TB?
Old Sep 23, 2006 | 03:25 PM
undrgnd's Avatar
undrgnd
You will probably experience some idle issues, rough running, stalls, but nothing major. The procedure is not that difficult, download the MREV installation manual here http://www.motordyneengineering.com/manual.pdf and look on page 9, everything you may need is there. Good luck.
Old Sep 23, 2006 | 04:06 PM
halfass872's Avatar
halfass872
[QUOTE=undrgnd]You will probably experience some idle issues, rough running, stalls, but nothing major. The procedure is not that difficult, download the MREV installation manual here http://www.motordyneengineering.com/manual.pdf and look on page 9, everything you may need is there. Good luck.[/QUOTE
Thanks!! Well i was lucky! Just so everyone knows who may womder. I had no probs at all. Started up like i did nothing different to the car. I unplugged the T.B., moved the throttle plate various times to get to all the nooks and crannys, and re-installed it, with no problems, without disconnecting the battery. I think the key is not to turn on the key at anytime while you have it unplugged, then the computer will never have a chance to realize anythign is different. Thanks to all!!
Stevo Z
Oct 3, 2015 09:14 PM
_bit
Oct 2, 2015 07:49 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
