VB upgrade
Old Sep 23, 2006 | 10:51 PM
jj350z's Avatar
jj350z
Default VB upgrade
What exactly is involved with the Vb install. I know I send it away and they beef it up. Then I get it back, and in my car it goes. However, How long does it take to get the vb out, and then how long does it take to pop it back in? Hour wise? Where is the Vb located on the trans?
Thanks!
Old Sep 23, 2006 | 10:58 PM
rookie's Avatar
rookie
Hope this can shed some light on the VB location/install. http://stillen.com/product_files/453335.pdf
Old Sep 23, 2006 | 11:02 PM
jj350z's Avatar
jj350z
Thanks, Id still like to know how long it would take a mechanic to pop out and install back.
Old Sep 25, 2006 | 04:31 PM
SGP_Racing's Avatar
SGP_Racing
Default The R&R takes no longer than 1hr.---->>>>>>>
A little longer with making sure that the tranny is filled properly...
Old Sep 25, 2006 | 04:55 PM
zzzya's Avatar
zzzya
It takes a little while to drain the fluid, then you remove the pan from the bottom of the trans and the VB is right there. After removing a few bolts and unhooking some wires it is out and ready to ship. Same basic process for putting back in but it takes a little longer to refill fluid unless you measure how much came out. If you are prepared going in, it takes an hour to remove and an hour to put back in, give or take 15 minutes each way so 1.5 to 2 hours total.
dcains
Nov 11, 2015 11:36 PM
