Vid of my weird JWT clutch.
Old Oct 1, 2006 | 07:57 PM
in2therain3's Avatar
in2therain3
Default Vid of my weird JWT clutch.
Here is a video of my clutch noise..
it dose it only when the clutch is put in or slipping the clutch
All the information should be in the video:
http://www.youtube.com/watch?v=iZ5_M8uYHTg
Old Oct 1, 2006 | 08:00 PM
edwin350z's Avatar
edwin350z
what noise?
Old Oct 1, 2006 | 08:30 PM
in2therain3
hear the little squeak/buzzing whatever you call it noise?
It is more apparent when I am reving in the beginning and when I am taking off with a slip.
Old Oct 1, 2006 | 08:45 PM
Xx SiFaKa's Avatar
Xx SiFaKa
Since you have a turbo in your car I will not pay attention to any other noises because turbos are music to my ears.
Old Oct 1, 2006 | 08:51 PM
edwin350z's Avatar
edwin350z
+1. love it!!
Old Oct 1, 2006 | 08:54 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
lol i only hear the turbo too. niceeeeeee
Old Oct 1, 2006 | 09:08 PM
in2therain3
Wow... you guys must be joking lol
Someone please tell me that they hear this noise!! (high pitched.. you can definatly hear when I am taking off!)
But thanks for the compliments!
Old Oct 1, 2006 | 09:10 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
sry but ur turbo is just too loud
Old Oct 1, 2006 | 09:13 PM
edwin350z's Avatar
edwin350z
i guess its one of those things that you have to hear in person.. do you feel it too?..(like a shaking or something)
Old Oct 1, 2006 | 09:33 PM
Xx SiFaKa's Avatar
Xx SiFaKa
I hear a high pitched Spool! Does that count?
Old Oct 1, 2006 | 09:46 PM
in2therain3
Hmm it is just weird that I can definatly hear it on the video...
It happens when my turbo is not spooling but when I am taking off from a stop
Here are another two vids (no clutch noise) if you guys want to compare it.
http://www.youtube.com/watch?v=j-iaywD8_D8
http://www.youtube.com/watch?v=qagni9Mr08w
Old Oct 1, 2006 | 09:48 PM
in2therain3
And yes I can feel it a little bit through the clutch pedal. (very slight vibration)
Frank at AAM ruled it out to throw out bearing but I need more input on this problem. It started happening after I adjusted the engagement point a little lower and yes I did without putting it down too far.
Old Oct 1, 2006 | 10:16 PM
Xx SiFaKa's Avatar
Xx SiFaKa
Girly robot voice - "In about two mile keep too the left!"
Lol Yeah I do hear what your talking about from the earlier vid just wanted to *** with you first. I hear if you have a Light weight Flywheel you will get a noise. Is it light weight?
Old Oct 1, 2006 | 10:22 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Does it only happen when your car is cold?
I thought I had a clutch problem until I changed my diff fluid, it turns out that it was just thick and sludgy (too thick) when the car was cold.
Old Oct 1, 2006 | 10:37 PM
Eazzy's Avatar
Eazzy
I hear a "hollow" whistling noise. How long has the clutch been in? Who installed it? Is it a complete JWT kit? Was the throwout brg replaced?How is it running on the street?
Old Oct 1, 2006 | 11:15 PM
in2therain3
No problems in the clutch. It runs great and grabs fine. Just the noise that bothers me sometimes. Clutch has been in for 2500 miles and the noise started after I adjusted my engagement point. AAM did the install and yes it was the complete JWT kit with the throw-out bearing. The noise doesn't depend on the weather from what I can tell and it is not getting any worse. It just anoys me when I hear it.. (little things bother me a lot)
Old Oct 2, 2006 | 03:50 AM
Peking's Avatar
Peking
Yeah it is to difficult to listen for a clutch noise with the vids. Would be more easy in person.
I have the JWT combo too, and there is some chatter... I chaulk it up to the much lighter fly-wheel.
But I have also heard other clutch/fly wheel combo's and some of them produce even more noise.
So at idle in a quiet area you can hear the fly-wheel chatter, not a lot just a little... Then if I press the clutch in it goes away, so when driving in parking lots of areas where I am in first-second gears... I am riding the clutch more to avoid making chatter sounds that others outside the car can hear.
Anywho good luck on figuring it out.
Old Oct 2, 2006 | 10:44 AM
in2therain3
Well, I know what chatter is and I am actually suprised how quite it is with the JWT clutch. Anyways, that hollow noise you hear is exactly what I hear in person.. nothing more or nothing less
Old Oct 2, 2006 | 10:53 AM
Eazzy's Avatar
Eazzy
All I can say is bring ur pedal back to where it was and see what happens--Just for a laugh if u havent already, is install a SS line and either way just chk for air ---After a bleed ---It needs another after a couple days to make sure all air is out, weather it be clutch or brakes
After that all that can be done is a disassembly and visual inspection by a talented eye
Old Oct 3, 2006 | 08:13 PM
in2therain3
I already do have a SS line but I will get it checked out again.
Anyone ever heard this noise before?
