Spark Plugs
Old Oct 2, 2006 | 05:51 AM
scshay's Avatar
scshay
Default Spark Plugs
hi guys i have a quick question i have a vortec g35 and a wile back i was asking serviceing questions and some of u recomended that i get plugs 1 degrese cooler.
so i bought some and im going to put thim, in they are ngk heat leval 6.
but i was wondering if i need to gap these?
thanks alot guys.
Old Oct 2, 2006 | 06:51 AM
trey.hutcheson's Avatar
trey.hutcheson
To my knowledge the NGK's come pregapped.
Old Oct 2, 2006 | 12:50 PM
QuadCam's Avatar
QuadCam
they come packaged at the stock gap.
Old Oct 2, 2006 | 06:04 PM
VIZAGE's Avatar
VIZAGE
I would highly recommend you still gap them yourself. Pre gapped not always 100%. Better to be safe than sorry. Only takes seconds to do.
Old Oct 2, 2006 | 06:17 PM
baileyrx's Avatar
baileyrx
the tips are brittle & can break very easily!
most will say dont gap
Old Oct 2, 2006 | 06:21 PM
MIAPLAYA's Avatar
MIAPLAYA
I got a set of NGK Iridium one step colder from Sharif and they were pre-gapped at .039. I just left them at that. My car has been fine.
Old Oct 3, 2006 | 07:27 AM
scshay's Avatar
scshay
ok thanks if i de decide to gap what would i gap thim at?
Old Oct 3, 2006 | 08:09 AM
MIAPLAYA's Avatar
MIAPLAYA
No less then .035. No more then .044
Old Oct 4, 2006 | 09:45 PM
scshay's Avatar
scshay
ok thanks sounds good
Old Oct 5, 2006 | 09:55 AM
97supratt's Avatar
97supratt
You're not supposed to gap any iridium plug because yes they are brittle and will break off.
You can only gap copper and platinum plugs. Personally I wouldn't even gap a platinum plug, only copper.
Old Oct 27, 2006 | 12:12 AM
Barzten1's Avatar
Barzten1
How many lbs should you torque the plugs when installing them?
Old Oct 27, 2006 | 07:36 AM
MIAPLAYA's Avatar
MIAPLAYA
I used German spec "Gutentight"
Old Oct 27, 2006 | 08:46 AM
rocks's Avatar
rocks
Close gap helps spark from blowing out in FI. I usually run like a .29 gap, but thats on coppers. Never ever put platinums in a boosted car.
Old Oct 28, 2006 | 04:02 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
You can gap an iridium plug just as easily as a copper plug - just make sure to use the right gapping tool (the disk type works well for these, I do not recommend using the prong type). If you are breaking the electrodes on either type, you're doing it wrong quite honestly. At the very least, inspect the gaps prior to install. While they do come pregapped, sometimes there are inconsistencies and better to find out before they go in
burglapfd
Dec 6, 2020 01:04 PM
350z82
Oct 1, 2015 06:25 PM
35reilly
Sep 28, 2015 07:42 AM
