B&M Rough Shifts
Old Jan 2, 2007 | 12:22 PM
gersteinp's Avatar
gersteinp
Originally Posted by NA&CH
well i think the b&m might be causing my third gear grind.(possible??) I am thinking of switching back to stock.
And then take it to the dealer to get it checked.
No shifter, short, stock or otherwise should have any relationship to gear clash. That's either a failure to fully disengage the clutch (i.e. engages too low or you replaced your summer floor mat with a thicker winter one); or, worn syncros.
Old Jan 2, 2007 | 02:57 PM
IIQuickSilverII's Avatar
IIQuickSilverII
Originally Posted by 97supratt
Stock shifter FTW!
I've heard a lot of horror stories about B&M with our transmissions. If I were to buy a short shifter for the Z, I would get it from 350evo. I haven't heard any complaints from their shifters. I'm not even sure if they still sell it, might want to ask around.
Good luck.
thats all they are stories....
mine was installed 20k miles absolutely no problem... at lil rattle first 10 miles which i took care off right away with an aftermarket shift ****
as far as the shifts go.... well i guess takes a lil time to adjust but after that its all fun... it really shouldn't take you that long to get used o it. I wouldn't do any hard shifting right away obviously until you are more used to it.. but yeah.. i mean some of the problems you are talking about are not really related to the shifter......
To start i would suggest keep the clutch pressed a lil longer until you are more used to the shifts...
Also for those skeptical..i dunno if half the people that bass it have even tried the 350z short shifter... many think it sits really low(which is not true) then the rattle and everything, but what did you expect with going aftermarket...some stuff requires more meticulous install and this is one of those things...without me considering a good mechanic i installed this and figured out how to fix the rattle
Old Jan 3, 2007 | 08:33 AM
NA&CH's Avatar
NA&CH
Could the shifter be installed correctly and not aligned correct? Causing me to hit the gear divide?? It is really weird. It was working ok about a month ago, just recently has it started to act up. Maybe I am thinking to much about missing third gear.
When I raced my buddies 07tl Type-s. Everytime I shifted into third it grinded, but did get in.
One of my last questions is will the dealer say anything about the SShifter?
Thanks a bunch guys.
Old Jan 3, 2007 | 08:34 AM
IIQuickSilverII
i doubt he will even notice its not the stock shifter
Old Jan 3, 2007 | 08:38 AM
Steve-O Z33's Avatar
Steve-O Z33
I have the fidanza and it was a little notchy at 1st. Now it seems fine. You have to shift a little harder but a good, weighted **** might help.
Old Jan 3, 2007 | 12:27 PM
NA&CH's Avatar
NA&CH
Thanks guys.
Chris
Old Jan 11, 2007 | 06:38 PM
ryan350z's Avatar
ryan350z
i tossed my b&m after a week, what a POS
Old Jan 12, 2007 | 09:51 AM
IIQuickSilverII
sherm
Apr 11, 2020 05:21 PM
hulkout
Apr 28, 2017 09:00 PM
ablaine
Nov 29, 2016 10:13 AM
Darkspy
Sep 7, 2015 09:09 PM
