Final Drive Gear - 3.5 vs 3.9
I ordered Cusco RS lsd and 3.9 final drive gears.. still got a few weeks to wait until they arrive.
I got bored at work today and created this graph with my dyno chart and gear ratio, the graph shows the chracteristics difference between the two gears.
I thought there could be someone who would want to see the difference in accel between 3.5 and 3.9 gears on a graph, so here we go
The 3.9 certainly makes a difference in accelaration, but I don't know if it is really that much more significant from a dead stop because you have to shift sooner as you get to redline faster. On the other hand when the car is already in motion it does accelerate quicker. Interesting chart.
BTW I have the 3.9 gears and I think it is the best bang for the buck mod for the 350Z.
Originally Posted by GodSendsDeath
What do you guys think, a boosted Z with the Twin set up from APS would be with the 3.9. I mean i dont think it would grab tracktion.
3.9 isn't that bad when you think abot it. i had a chevelle that had 4.11's. that is a common setup up in many muscle cars. i have a few friends that run 4.32 in their novas. those cars take off.
on another note. your gas mileage will go down a bit.
you can't really compare final drives from different cars unless they have similar transmission gear ratios
it's possible to have a car with a 4.11 be way weaker overall in each gear than a car with a 3.3 with shorter transmission gears
it partly depends on how many gears the transmission has
whether from a roll or a dead stop, the 3.9 gears are equally effective...its a static change you are making, it is not rpm dependant. Everything will happen ~10% quicker.
Works great for a NA car, especially one with a raised rev limiter. Works REALLY well on a supercharger like a Vortech, which makes all its power up top. On the twin setups, might not be the best mod as the boost tends to come in fairly quickly due to the bigger displacement and compression these motors have.
My question is are you guys considering this mod for road racing or 1/4 mile racing? I've done the gear ratio calculations and the stock 3.5 gear is actually more ideal in a 1/4 mile race when you consider ending/beginning torque on each successive shift. Deeper gears will ALWAYS give a greater sensation of acceleration, but when timed, it may not be an advantage.
So let me get this straight. Judging by your chart, a Z with the stock 3.5 final drive can hit 295km/h where as the 3.9 can only hit around 270km/h. This is of course with the speed limiter removed.
Yes that is correct
Because, i used to have a 04 330ci, boosting 8psi on the ESS kit, with my 3.68 i had no traction first gear. But i had 9.5 in the back for rubber grip. I thought with maybe 20x10 in the back. Its for road use only i don't track my cars. Hmm iam sorry to sound like a new its i honestly dont know **** bout the Z. I don't even have one, but I am buying one. It was that or a M3. But with the money i save from not buying tha M3 i can get a second condo to rent out and make some more money that way.
Originally Posted by hunter6
I'm gona get flammed for this but...what do the numbers on the left side (vertical) column represent?
